Old 09-30-2004, 11:32 AM   #1
Bad injector harness = CEL?
My Ride: 2k2 Neon
Engine: 2.0
If I had a bad injector harness, would that trip a CEL? or would it only trip the CEL if a wire was completely broken? (I'm thinking I might have a corrosion issue which would effectively alter the resistance)
Thanks
Steve
neon_steve is offline
Old 09-30-2004, 12:40 PM   #2
If it can't fire the injectors properly (open or shorted circuit), you'll get a code 26 or 27.
If the CEL came on, there's a code stored for it.
lametec is offline
Old 09-30-2004, 12:46 PM   #3
My Ride: 1987 Shelby Z
1/4: 11.620
I have had both bad injector harness plugs and bad injectors (at different times) w/o a CEL.
B.A.P. is offline
Old 09-30-2004, 01:23 PM   #4
My Ride: 2k2 Neon
Engine: 2.0
Aight, well I guess I better just build a new harness and get my injectors checked (Whichever happened melted a piston)
Thanks!
Old 09-30-2004, 01:24 PM   #5
Right. Code 26 and 27 don't turn on the CEL light.
lametec is offline
Old 09-30-2004, 08:29 PM   #6
My Ride: 2k2 Neon
Engine: 2.0
Hmm, looks like I better be looking into a scanner..
Old 10-01-2004, 06:23 AM   #7
My Ride: 1987 Shelby GLHS 189
Just pull a resistance check on your current harness. I hust verified 2 harnesses I had were good doing this.
glhsken is offline
Old 10-01-2004, 07:33 AM   #8
My Ride: 2k2 Neon
Engine: 2.0
I'll probably do a continuity check on all the wires, and then check the resistances with the injectors plugged in. What should the resistance of the injectors be? 2-3ohms?
Old 10-01-2004, 07:35 AM   #9
all I have tested that were good were in the 2.3-2.6 ohm range.
glhsken is offline
Old 10-01-2004, 07:37 AM   #10
My Ride: 2k2 Neon
Engine: 2.0
Thanks Ken
Loan | Personal Loans | Repair Bad Credit | Facebook Proxy | Proxy
Page generated in 0.40020 seconds with 13 queries
