Old 10-26-2004, 12:44 AM   #1
Tach Signal for Shift Light
My Ride: 85 Shelby Charger
Engine: 2.2L Turbo II (GLHS)
Does anyone know where I can pick up a tach signal to run a shift light with on an 85 Shelby Changer? I see that there is a ignition reference signal at one of the LM connectors, but will it work? Or is there a tach input going to the power module that I can use? There is also a tach output signal at the LM connectors, but I would think it just is a variable voltage to run the gauge, so it wouldnt run a shift light. Any help would be appreciated. Thanks.
fish2222 is offline
Old 10-26-2004, 12:57 AM   #2
My Ride: 89 Daytona ES
Engine: 2.2L TII
I show on my databases:
1984-87 Dodge Charger Information
Signal = Tach
Wire Color = Black
Where = Coil
Just not 100% sure what kinda signal the shift light requires
diabloed is offline
Old 10-26-2004, 08:04 AM   #3
Shift lights require low voltage. The tach signal for a shift light can easily be picked up from the negative wire of the coil. In the later models, this is the factory gray wire (w/black tracer).
White Lightning is offline
Old 10-26-2004, 11:04 AM   #4
yeah, the tach output signal is what you want. it is the same pulsing signal that you would otherwise pick up off the coil, but without all the timing advance and noise you would get with that.
xrattiracer is offline
Old 10-27-2004, 04:52 PM   #5
Ok then, heres a question. Will the ignition reference sensor input on the ECM work for a shift light? I would think it is just the pickup from the distributor, isnt it? Or will that only work on the 86 and 87 years?
fish2222 is offline
Old 10-27-2004, 06:21 PM   #6
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Yes, the LM tachometer output is a very clean signal, should work great for your shift light. I've used it to trigger the Megasquirt EFI computer on a couple cars.
Una is offline
Old 10-27-2004, 11:09 PM   #7
Is the tach output a pulsing signal though? I thought the LM converted the input from the ignition reference signal to a voltage type signal to run the tach. I didnt think the tach would run straight off a pulsing signal, but of course I could be wrong....
fish2222 is offline
Old 10-27-2004, 11:25 PM   #8
yes, the tach signal is what you want, i guess i didnt explain good enough in my other post. it is a pulsing signal, one pulse per firing event. this is what tachometers and shift lights want.
Old 10-28-2004, 01:21 PM   #9
I am just asking if the tach output to the gauge from the Logic Module is pulsed or just a voltage signal to run the gauge. I know that I need a tach signal to use, but I am not sure if that output is pulsed or not that actually runs the tach, since it doesnt come directly from the distributor.
fish2222 is offline
Old 10-28-2004, 01:59 PM   #10
Una
Engine: 2.5L Turbo
Originally Posted by xrattiracer
yes, the tach signal is what you want, i guess i didnt explain good enough in my other post. IT IS A PULSING SIGNAL, one pulse per firing event. this is what tachometers and shift lights want.
What part of the previous reply did you miss? IT IS A PULSING SIGNAL. I probably sound harsh, just trying to make sure you catch the answer that was already posted.
Una is offline
Old 10-28-2004, 02:25 PM   #11
I read the post right. It just didnt specify that the tach output FROM the LM was pulsed. It just says tach signal. That could be from the coil, the distributor, etc... I was just trying to clear that up.
fish2222 is offline
Old 10-28-2004, 03:11 PM   #12
Una
Engine: 2.5L Turbo
The tach output from the logic module is pulsed. One pulse per ignition event.
Una is offline
Old 10-28-2004, 05:03 PM   #13
Thanks for clearing that up. Maybe I misread something, but thats all I was asking. Thanks.
fish2222 is offline
Old 11-19-2008, 05:49 PM   #14
Re: Tach Signal for Shift Light
My Ride: 2003 SRT-4
Engine: 2.4L Turbo
Looks like this thread died a few years ago, but maybe someone is still out there that can help.
I have an 03 SRT-4 and I need to find an RPM (tach) signal for a shift light. I don't want to have to get a tach driver. One of the mechanics at the dealer here in Tulsa told me he found it in a manual a few years ago, but had no luck while I was there. There is a lot of talk about this on other Forums, but I haven't found a solution.
Thanks!
Harry Higear
harrym is offline
Death Note Episodes | Credit Cards | Credit Check | Auto Loans | Mortgages
Page generated in 0.72372 seconds with 13 queries
