Old 10-30-2004, 11:51 AM   #1
Question CODE 53 = bad voltage drop?
shelbeeclimber
First off read the codes and i have a CODE 53 (internal Module failure)is this in any way connected to when i turned on all the goodies in the daytona and have major voltage drops. With just the lights on it drops down about 1 1/2-1 volts when i added the both front and rear wipers and defrost again another 1-1 1/2 volt drop won't even go into what happened when i turned the stereo on. All in all voltage dropped to about 1 hash mark over 8 volts! Not Cool!? Also having issues when at idle the power steering pump starts whinning are the three issues connected. The alternator is about 6 months old (90amp) Seems to be bit much of a voltage drop please advise o wise ones.
Thanks
Matt
Old 10-30-2004, 03:42 PM   #2
My Ride: 87 Daytona Shelby Z
Engine: 2.5L
Code 53 means that the data on the ECU's EPROM doesn't match the checksum value. You either have a custom cal, or the chip is corrupted.
If you have an aftermarket ECU don't worry about it, it doesn't trigger any limp in modes, if you have a stock ECU, get a new one.
Thanks
Matt
MRBOOST is offline
Payday Loan | Online Loans | Credit Card | Remortgages | Mobile Phone
Page generated in 0.35878 seconds with 13 queries
