Old 11-08-2004, 03:14 AM   #1
I have discovered other problems.
Along with my fuel pump not priming, I also have no spark.
I should have checked that earlier for everyone's sake.
I don't know if it could be the SMEC or connections, because I still get full dash display and error codes (currently just 11 and 12).
Everything appears to be connected the way it was before the engine was ever pulled.
I figure I may need to swap a SMEC to make sure it's not that.
I'm at a loss otherwise.
Chadxton is offline
Old 11-08-2004, 09:28 AM   #2
Code 11: Bad HEP or wiring.
No fuel/spark with bad HEP.
lametec is offline
Old 11-08-2004, 09:47 AM   #3
When the fuel pump does not even prime, 99% of the time it's the SMEC or your ASD relay could be bad.
Mark
89 CSX 16 valve is offline
Old 11-08-2004, 11:55 AM   #4
I should have listened the first time!
Thanks
Chadxton is offline
Old 11-15-2004, 08:15 PM   #5
My Ride: 86 LeBaron GTS
Engine: 2.2 turbo t2 conv.
now that you found out its not the computer, whats next?
dammnit88 is offline
Old 11-16-2004, 12:01 AM   #6
I don't know.
Chadxton is offline
Electricity Suppliers | Credit Cards | Stoves Range cookers | Per Insurance | Personal Finance
Page generated in 0.32556 seconds with 13 queries
