11-12-2004, 12:37 AM
#13
Originally Posted by 88BlueShelbyZ
Ya know, that is a great question. Because I want to know the pressure after the AFPR so I know what it is set at. And if that is the case I would need to use the schrader valve, which everyone says not to use. I guess I will just order the kit from FWD that allows you to use the schrader.
-Mike
you do not measure the pressure after the FPR, using the schrader valve is still before the FPR.
