Old 11-17-2004, 11:35 AM   #1
3 bar map sensor voltage
My Ride: DOdge Shadow ES
Engine: 2.5l
Does anyone know what the voltage output of a 3 bar map sensor should be and what pressure it corresponds to? Any help would be great. Thanks
DJ
turboshad is offline
Old 11-17-2004, 01:26 PM   #2
My Ride: 1991 Spirit R/T
I tested my 3 bar MAP sensor by applying varying pressure to it and noting the corresponding voltage output. I found the following equation to work quite well-
psi = (MAP Voltage - 1.67) / 0.113
4sfed4 is offline
Credit Cards | Loans | Mortgages | Remortgages | Property Search
Page generated in 0.32596 seconds with 13 queries
