11-18-2004, 08:32 AM
No more overboost! YEY!
My Ride: 94 Ford Lightning
Engine: 351W v8
Welp, I made the adjustable zener diode from spoolboy's site the day before yesterday. Very easy design. I think the parts cost me around $10...maybe a little less
$2.50 for 50 of the diodes (you only need 2, but they come in 50)
$2.50 for the potentiometer
$2.00 for some fine silver solder
$1.00 for a few little pieces of shrink tube
$3.00 for 2 new tips for the ol' soldering gun.
I found some old chunks of wire i had lying around, and did it up...shrink tube hides ugly soldering jobs.
Then, yesterday, I had a few spare minutes, so I soldered it into the map sensor wiring. That was easy.
Then, very unscientifically, this morning I got in the van with a handy-dandy precision screwdriver (eyeglass), and headed to work. I must have stopped and gotten out and adjusted that thing 10 times on the way here. Overboost, overboost, overboost....no overboost!
On the last adjustment before I got to my office, I finally got it low enough to not hit overboost. I actually went a little too low, as I strayed from blue to green a little on the dawes device. So, on the afternoon drive home it'll be all about turning it up to the very brink of overboost.
What a beautiful little device. I can't see how any other method of 'fooling' the map can compare to this one. The non-adjustable zener, unless you are VERY lucky, is going to cost you a little bit of fuel. The grainger is going to be finicky because of weather (winter to summer)...and this thing is cheap and easy to make!
damon
