Old 11-19-2004, 08:39 AM   #1
Overboost shutdown @ 13 psi?
My Ride: 94 Ford Lightning
Engine: 351W v8
Hey guys. I finally got my boost gauge hooked back up, after spending a week trying (and eventually suceeding) to stop overboost shutdown.
Well, today, I backed off my diode to let the map function normally, to see where overboost shutdown happens. It seems like it's happening @ around 13 psi. Isn't this a little bit low?
It is possible that the gauge isn't right, but it registers 0 at 0 and -18 at idle. That would make a guy assume that it's pretty durn close.
Any ideas on that one?
Thanks!
damon
Subliminal is offline
Old 11-19-2004, 08:48 AM   #2
My Ride: 1987 Shelby GLHS 189
Depending on the computer, that is where the shutdown occurs.
glhsken is offline
Old 11-19-2004, 08:51 AM   #3
Engine: 351W v8
Really? I thought it was always 14.7. This is on an 89 2.5 t1.
Oh well, doesn't really matter, i just thought it was a little weird.
The big can, 20s regulator and rail are going on this weekend, so we'll see what we can do about that crappy 13 psi shutdown.
Old 11-19-2004, 10:06 AM   #4
My Ride: 85 Daytona Turbo Z
Engine: 2.2 L Turbo II
Interesting, because I have an 89 2.5 T1 and I seem to hit boost cut at 14.7.
Leafy is offline
Old 11-19-2004, 10:14 AM   #5
boost cut out eliminator
Good stuff there
glhsken is offline
Old 11-19-2004, 10:24 AM   #6
Engine: 351W v8
Ken,
That particular thread seems to be more about the variance in zener diodes, rather than a variance in map sensors.
If my boost gauge is correct, the computer is cutting fuel when it sees 13 psi, rather than the full 14.7.
Old 11-19-2004, 10:28 AM   #7
There is a post there explaining this... it references gary's page...
glhsken is offline
Old 11-19-2004, 10:32 AM   #8
Engine: 351W v8
There's two posts there that reference Gary's page.
The first one basically says that a 4.3v won't give you all your fuel, but a 4.7 might be too much and still hit overboost. I would assume this is because of the loose tolerances of the $.50 zener diodes.
The second one basically says the same thing.
I'm still a little confused. Could ya spell it out for the slow one (me)?
Old 11-19-2004, 10:46 AM   #9
this is the key statement
"If you have a stock computer, you must use the 4.3v diode. If you use the 4.7v the boost reading the computer still sees is higher than the programmed boost "target" and you will still get overboost shutdown. You must have a MP computer to use the 4.7v diode, they have a higher "target" boost voltage and won't shut down at the 4.7v map sensor reading"
basically, mp computers shut down at 14.7psi based on the tables. Non mp or stock computers have a lower programmed "shutdown" point. Not sure exactly what thap psi is, but it would be lower than 14.7.
glhsken is offline
Old 11-19-2004, 10:49 AM   #10
Engine: 351W v8
Roger that...read between the lines, damnit Damon!
I wonder if they intentially did that so that their performance computers actually held a performance edge?
Old 11-19-2004, 01:07 PM   #11
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
On the stock 2.5 T1 ('89 MSEC and '90/91 SBEC), OB shutdown is 13.6 psi.
The MP computers for the 2.5 T1 have the OB set at 14.0psi.
Shel-Game is offline
Old 11-19-2004, 01:29 PM   #12
Thanks!!!
glhsken is offline
Old 11-19-2004, 01:35 PM   #13
Weird! for my mini, it was around 14.7 psi??????
Old 11-19-2004, 02:06 PM   #14
Engine: 2.5L T1
As read on the guage? I think they are only accurate to 0.5psi or so.
Also, the computer calculates boost above baro, but the guage is (usually) calibrated to standard atmosphere (1-bar, 14.7psi). So, if your local barometric pressure is higher than 1-bar (say 14.9psi), then the guage would read higher than 14.0 psi, even though the computer would only be calculating 14.0 psi boost.
Old 11-19-2004, 02:24 PM   #15
Sea level, autometer boost guage. Close enough to 15 psi so I figure 14.7 was accurate!
But as people are finding out, every car/van is different!
Free Advertising | Free Online Games | Credit Card | Credit Cards | Mortgage insurance
Page generated in 0.43753 seconds with 13 queries
