01-18-2005, 08:22 AM
HELP!!! misfire, code 27!!!
Title says it all.....over the weekend, car started shaking and vibrating, running horrible, threw a code 27 (i know what the code means) but kind of at a loss as far as a fix goes.....when idling, i can press down on the #3, #4 injectors and the car gags, sounds like it wants to shut off....ive checked connections, they seem fine visibly but havent pulled the injector harnesses yet....i did notice the ground from the back of the intake to the firewall was in two pieces, so i replaced the ground, did nothing! seems to me like it could only be the injector harnesses, or maybe a HAL plate? havent pulled the distributor yet.....anybody?
btw, car is a 91 shadow, w/2.2 head, garrett, intercooled
