Old 01-26-2005, 09:58 PM   #1
diode
My Ride: 86s/c
Engine: 3000
1/4: 15.300
i have a 10 diodes 5 4.7 and 5 4.3 when i figure out which 1 my computer works with how would it change the fuel cut out or how would it benifit my 86 sc
86shelby15psi is offline
Old 01-26-2005, 10:35 PM   #2
The diode is going to dump excess voltage " above 4.3 or 4.7 volts - depending on which one you use" to the MAP sensor to prevent it from going into overboost shutdown. This allows you to up the boost but dont forget you will have to also add more fuel to compensate! Check out Gary Donovans website at www.thedodgegarage.com and look under the turbo database link. He has a article specifically on this issue which should answer all your questions.
DUGZSHELBY is offline
Keeping Aquarium Fish | Credit Card | Myspace Layouts | MPAA | Loans
Page generated in 0.72966 seconds with 13 queries
