Old 03-10-2005, 11:37 AM   #1
Cool performance smec for 2.5 van
What is a good perf. smec for a 20%, 3 bar, fmic set up.This is for my 89' caravan 2.5L auto. Im looking to run 20 psi. Also where do I obtain such an item.
jimcharlie is offline
Old 03-10-2005, 11:46 AM   #2
My Ride: 94 Ford Lightning
Engine: 351W v8
If I were you I'd go to www.******************** and talk to them. They kind of cater them to your needs.
20 psi will be about the max on +20s, from what I understand. You might want to run 18 or so, just to be safe.
d
Subliminal is offline
Old 03-10-2005, 12:26 PM   #3
d
Depends on the turbo, what his setup is etc. There all different. I got 23 ish PSI on +20's and 18 on the stockers with the stock turbo, ported head etc.
Old 03-10-2005, 02:08 PM   #4
Engine: 351W v8
Simon,
You're a good guy, and very informative, but you always type stuff like this, and I think you've been using extra injectors as well. On straight +20s, without extra injectors, I haven't heard of too many running over 20 pounds...it doesn't sound very safe to me. If 15 psi is around the ragged edge of the stock fuel system, 20% more would bring you up to about 18 psi.
I'll state it again, mr. moderator, mr. my dog is better than yours, you have to mention those extra injectors when talking about said subject.
damon
Old 03-10-2005, 04:07 PM   #5
My Ride: 89 Caravan
If you havent bought the injectors yet, I would go with some +40's and run some wicked boost with that 3 bar cal.
But yes, go to ******************** have heard nothing but good things with thier programming.
Jeff
My96z is offline
Old 03-10-2005, 04:26 PM   #6
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
turbosunleashed should be able to tell when they're doing the cal if the duty cycle on the +20's is going to max out or not..
Una is offline
Old 03-10-2005, 04:37 PM   #7
Simon,
damon
dude, my pound has your dog!!!!
Anyhow, sorry, to clarify, I ran the +20's with no extra injectors and had plenty more fuel to go at 23 psi. I ran the stock injectors at max duty cycle and 3 cold starts at 18 psi-stock turbo.
With my new setup, Paul said 18 psi max with my +20's and full duty cycle.
Pffttttttttt.
And I still stand by its almost impossible to guess max psi on any injector as every car/van is different.
Old 03-10-2005, 06:23 PM   #8
Engine: 351W v8
Yeah, you have this nasty habit of forgetting about those extra injectors when talking about your fuel system.
"Sure, you can run 20 psi on stock injectors." when you mean "Sure, you can add extra injectors to the stock system to support 20 psi."
Think of the newbies, man!
Old 03-10-2005, 07:12 PM   #9
1st time I forgot, Find the other times I forget, I triple dog dare you!
Old 03-10-2005, 09:33 PM   #10
Engine: 351W v8
I like ya man, and not trying to make an enemy or anything, but I've got to accept your challenge.
+20's.... how much boost, all the time?
I could only find two. I remember back when I was trying to learn about extra boost based on the different fuel setups specific to these cars, i think maybe you were experimenting with it on your van too.
And beyond that...stop trying a frickin hilter.
Old 03-10-2005, 09:56 PM   #11
Hahaahaha, there the same thread, ooops!! And that one was with my +20's with which I don't use the cold starts. I only used them with my stockers,
I apprecitate the effort but when all is said and done, your dog sucks,
Old 03-10-2005, 10:08 PM   #12
Engine: 351W v8
You're just jealous, and YOU know it.
Old 03-10-2005, 10:11 PM   #13
Hahahaahhhaa, I kill me,
Old 03-15-2005, 11:00 AM   #14
mwadams's Avatar
My Ride: 87 GLHS
Engine: 2.5 T2
I am running +20's in a 2.5 and have a cal set-up for 20psi. I definately wouldn't want to run any more than that, but I get 9-10 lights at WOT with my set-up (at stock FP).
Mark
mwadams is offline
Old 03-15-2005, 11:08 AM   #15
Right now I am running 16-17psi with the stock injectors and one cold start. Still a little rich at wot. Have not done a calibration change yet but I would try TU or FWDperformance to get some more info.
nvr2old is offline
Remortgages | Remortgages | Loans | Books | Bleach Episode
Page generated in 0.46261 seconds with 13 queries
