Old 03-11-2005, 11:16 PM   #1
Name that injector.
My Ride: '88 Sundance
Engine: '89 2.5 TI
pn. 4418335
Wondering what the flow rate is on these? I checked Gary's site and all I could find is "unknown on '89-93 fuel rail, not a good part number".
These were on my '88 Daytona Pacifica (2.2-T1) but I found a recipt in the glove box where a PO had a shop change the engine, so who knows where any of the parts came from...
I changed them out in favor of a set of known good 4418258 injectors ('89 T2 33 lbs/hr) while trying to find the source of a miss at idle. I'm just curious to know if there is any difference in flow rate between the 2 sets of injectors.
Also, while I'm on the subject, I pulled the injectors out of the '89 2.5 I got from a local salvage yard and they had no part #'s what so ever. Wierd!
Thanks,
Tony
tonyz2897 is offline
Old 03-12-2005, 11:38 AM   #2
My Ride: 1991 Daytona Shelby
Engine: 2.5L
Yes there is a difference. The 4418335 injectors are the 27lb/hr injectors. There should be an H on them.
Frank
Frank is offline
Old 03-12-2005, 12:31 PM   #3
Engine: '89 2.5 TI
Thanks Frank! So, the 33 pph injectors should be a slight upgrade then? The computer doesn't seem to have any problem with them. The A/F guage is bouncing like normal at idle and part throttle and holding 9-10 leds (10 led guage) under boost.
Thanks again,
Tony
Personal Loans | Credit Counseling | Finance | Money | Horoscopes
Page generated in 0.23841 seconds with 13 queries
