03-15-2005, 07:18 PM
My Ride: 91 Spirit R/T
Engine: TIII
The fuel will be unevenly distributed between the cyllinders and 2 will run lean and ruin pistons when running the TI ECU. So, yeah, you'll have to change it. Doing the wiring isn't very difficult once you get into it. How were you going to control the idle without updating the wiring and ECU?
Grinding the notch into the exhaust manifold isn't tough to do either. Put your TII turbo on the flange and mark where you need to grind the manifold.
