Old 03-28-2005, 03:39 PM   #1
Pix wanted: 3 bar MAP sensor in a GLHS
My Ride: 1986 GLHS #126
Engine: stock
Paul at TU tells me their 3 bar logic modules for the GLHS car are ready to go, but the buyer must take care of a new 3 bar MAP sensor installation.
Has anyone installed one of these TU LM's in their GLHS and if so can you post pix of the 3 bar MAP sensor installation? thanks.
Marcus86GLHS is offline
Old 03-28-2005, 04:22 PM   #2
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
just use a GM syle 3 bar map sensor from Summit Racing. You'll need a connector as well since the stock Chrysler connector will not work on the GM sensor.
Wink
mwinkle353 is offline
Old 03-28-2005, 04:23 PM   #3
Engine: stock
yes thanks but i need pix to show the install, i do plan on getting the sensor from TU.
Old 03-28-2005, 04:36 PM   #4
Engine: 3.0L V6
http://hhscott.com/93tmv/3-bar_map.htm
Found this on the web.
Wink
Old 03-28-2005, 04:49 PM   #5
My Ride: 88 sundance
wow great info because i'm gettin ready to start upgrading
jdawg is offline
Old 03-28-2005, 05:38 PM   #6
Wink
Yes it will, you just have to cut out a bit of the connector, you'll be able to see what I mean when you look at the connector and sensor.
Old 03-28-2005, 05:46 PM   #7
Engine: 3.0L V6
Damnit. You're right. I was thinking of the map sensor connector on the 3.0L for some damn reason. Man, I need to keep the different motors better seperated in my mind. Cause it's statements like this that make me look more ignorant that I really am. LOL If that's possible.
Old 03-28-2005, 05:46 PM   #8
Engine: stock
i dont think the glhs cars use the grey connector shown in the link above.
i was hoping to view a glhs-specific install, remembering the cars use a logic module and a power module, not a SMEC like the later turbo cars.
thanks for link, but i still cant picture how the heck to install the MAP sensor to the LM.
Old 03-28-2005, 05:49 PM   #9
Engine: 3.0L V6
Do you know where your stock map sensor is? If so, and if the connector won't fit into the 3 bar map you purchase; then just get a 3 pin weather tight connector and splice into the original map sensor wires.
Old 03-28-2005, 06:26 PM   #10
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
with a GLHS you'll have to install an underhood map, or mount the 3bar near the LM in the car...
I had a pigtail from a map sensor that I plugged into the LM, then ran the connector from there, through the hole for the vac tube that was through the firewall grommett.
Then, I wrapped the wiring, put it in conduit, mounted the underhood map on the inner fender, hooked up the baro solenoid, ran a new vac line, and presto - underhood map. Much cleaner, easier, and better throttle response too.
This was on my charger btw.
Phreakish is offline
Old 03-28-2005, 07:02 PM   #11
No worries, we all make mistakes.
Now Marcus has me wondering, haven't seen an Omni Map in ages so can't remember what the connector looks like now, doh!
Old 03-28-2005, 07:06 PM   #12
Engine: 2.2 Turbo
its 3 wires (duh) flat, and it connects on the MAP sensor (mounted on the LM), and a vac line goes into the LM (onto the map). When I bought a used LM from an '86 lebaron years ago it had a pigtail and a 'cover' (gutted stock MAP). So I ran an underhood map with it.
Old 03-28-2005, 08:42 PM   #13
My Ride: 87 Daytona Shelby Z
Engine: 2.5L
That connector in the picture at the bottom of that page is what you need. The connector for the internal MAP is a different shape and that's why it needs to be changed to use the 3 BAR.
What I was saying in that PM a while back is if you can get a connector with a length of wire from a yard I'll solder it in for you since we haven't been able to get anywhere on developing the jumper harness.
MRBOOST is offline
Old 03-29-2005, 06:03 AM   #14
Engine: stock
good info.....a picture of a 3 bar map sensor actually installed in the LM would do me a world of good. pix speak a thousands words like they say.
CHRIS can you snap a pix of this mod from one of your customer cars? once i feel confident i can accomplish the MAP swap i can then order one of your calibrations, thanks.
Old 03-29-2005, 08:48 AM   #15
Is the retrofit kit still available from Mopar?
supercrackerbox is offline
MPAA | Personal Car Finance | Loan | Remortgages | Loan
Page generated in 0.46380 seconds with 13 queries
