03-31-2005, 05:46 PM
Fuel pump problems
NO Democracy!
Just recently, my fuel gauge started moving more than normal on acceleration. I didn't think much of it at the time, until a few nights ago doing some street racing where I ended up starving the pump hard core with a 1/4 tank (never ever been a problem with this car). The car essentially bogged real bad on the 1st series of races when I floored it (very embarrassing... read my post in street stories under best VNT race yet! I won later on btw;-) The 2nd series that I won, I noticed that the car just stopped pulling at 130mph. Pulled hard at 120+ just peetered out at 130. I added a few gallons before those runs as I figured it was the pump having issues picking up the fuel. I have run the car hard at that speed before so I know it certainly was far from done at 130.
Can anyone tell me what is happening to the pump assembly? I figure something's loose now, pickup fell off, or...?
Also, I don't understand how my pistons made it through that.... 4 times!
I replaced the pump in thge car 2 times. 1st time... aftermarket oem type replacement and 5k miles later, pump won't hold more than 67psi at 4,000 rpms... and falling. The pump in it now is a back up correct application used pump that worked fine for the past 30,000 miles that I installed 4 years ago.
Thanx.
Steve
04-01-2005, 10:09 AM
My Ride: 1986 GLHS #065
Engine: 535hpAluminumLongRod
1/4: 11.921
the pump is probly fine. the problem is most likely the power supply to it. this is a common problem with many older cars (DSM's ALWAYS have this issue!!!!) my friends GLHS had the same problem. We noticed it on the dyno on the under hood FP guage. it made it to like 68psi then dropped down to like 61psi still @ 30psi boost
To solve this problem get a heavy duty relay some 4 or 8 guage power wire for a stereo, and a distribution block and a fuse. run the power wire to the trunk or back seat (wherever the pump is) find the wire powering the pump (green on my omni) cut it and use it to turn on the relay then connect other side of relay which now uses the large power wire. this stops voltage drop to the pump and is the only way to max out a pump, even a 255. good luck.
04-01-2005, 11:21 AM
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
You may have lost the pickup sock or the plastic baffle around it popped loose from the bottom of the tank.
Luck, probably. You probably went from running straight to miss-firing before it had a chance to really detonate hard. I would do a compression check, though.
FPG would tell the tale.
04-03-2005, 02:28 PM
My Ride: 91 Spirit R/T
Engine: TIII
With the engine at idle you should be able to get a bare minimum of 1 pint in 15 seconds. I prefer to see closer to a quart if the engine is anything above stock. This is done with your fuel pressure gauge hooked to the schrader valve and the botton or port open to measure the flow. Make sure your hose is long enough to get to a catch can on the ground. Also, take notice of the fuel pressure while doing this to make sure it doesn't drop much.
04-04-2005, 12:52 AM
Fuel pump T2 = T1
My Ride: dodge shelby lancer
I have fuel issues with my Dodge Shelby Lancer. I was wondering if the turbo pumps are the same, because I have T1 pump installed right now. I am running 14 psi of boost and a larger Volvo intercooler.
Thank you for your information.
