Old 04-03-2005, 09:49 AM   #1
3-bar map voltage:boost ratio?
I need a calibration!
Akromix's Avatar
Going to do some datalogging once the car is back up and running with the PLX M-500 and was wondering what the voltage:boost ratio is and the min/max of the 3-bar. I know 29psi is max, but I don't know what the minimum (most vaccuum) it can see is. Any help would be appreciated.
Thanks in advance
Akromix is offline
Old 04-03-2005, 07:09 PM   #2
My Ride: No slicks Omni
"Rough" numbers using my scanner and dattalogger:
.80v idle/vac
1.7v @ 10psi
2.4v @ 15psi
2.8v @ 20psi
3.6v @ 22psi
3.7v @ 23psi
russ jerome is offline
Old 04-04-2005, 12:33 AM   #3
Akromix's Avatar
.80v idle/vac
1.7v @ 10psi
2.4v @ 15psi
2.8v @ 20psi
3.6v @ 22psi
3.7v @ 23psi
Thanks Russ, this is Jason (I met you at Bryan Lugert's place last summer during a bonfire, was the passenger in the white turbo lebaron that we all checked cam timing on)
Akromix is offline
Credit Cards UK | Mortgage | Cheap Loan | Credit Counseling | Mortgages
Page generated in 0.28488 seconds with 13 queries
