Old 04-09-2005, 09:49 PM   #31
My Ride: 1986 GLHS #126
Engine: stock
went to autozone and peps boys today, both stores sell on their pegboards a fitting that is close: its a 5/16's straight thread with a flaired and o-ringed steel tube that seats/seals on the accufabs seat at bottom of units fuel inlet. prob is the fitting doesnt have a bulge or barb to ensure hose wont slip off the steel tube so i took a pass on the part. the important aspect is that the correct fuel inlet seals with a flair/o-ring on a seat, not on the threads themselves (ie: NPT).....if youre using a male NPT thread sealed into a straight female thread you have a seriously unreliable seal that is nothing shy of a hack job.
Marcus86GLHS is offline
Old 04-13-2005, 11:40 AM   #32
Engine: stock
ok the fitting does go into the return portion of AFPR, someone just informed me the fuel inlet is always direct to the rail (thanx Jonny).
but, still the return line is under quite a bit of pressure, certainly enuf to spill a lot of fuel onto a hot engine and cause a fire should the return line leak at the AFPR.
Old 04-15-2005, 07:46 AM   #33
Engine: stock
.....thanks to the info from members here and the help of a local buddy, i'll be installing this (Accufab w/ steel fuel return line from an '89 TII):
Old 04-15-2005, 01:13 PM   #34
My Ride: 1987 CSX
Images: 4
awsome take some pics when it's done!
RSTURBO is offline
Old 04-15-2005, 01:38 PM   #35
Engine: stock
wtf...not sure why pix isnt showing, trying again....
Old 04-16-2005, 01:05 AM   #36
My Ride: 1987 CSX
Images: 4
Wow that looks great! Mind me asking why you picked acufab over the bosch unit?
RSTURBO is offline
Old 04-16-2005, 04:05 AM   #37
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Don't forget the mounting washers. I needed two on each mounting stud to prevent the inlet hex piece from going too far into the reciever cup on the rail. This left barely enough of the studs protruding to get the mounting nuts back on.
iTurbo is offline
Old 04-16-2005, 06:04 AM   #38
Engine: stock
yup, TU included these instructions, but no washers.
RSTURBO i picked the Accufab soley based on the many posts/people on this website recommending it.
i painted over the "accufab" logo, and painted the diaphragm retaining cap screws to make the whole unit black, and less noticeable underhood. once i get the fuel pressure dialed in i'll paint the adjusting screw also.
Old 04-21-2005, 08:55 AM   #39
Well,
I got back on this last night, and low and behold, it leaks! So I guess It's off to the bone yard this weekend to look for a T2 line. So, please disregard my earlier post (quoted below).
BTW, how do you edit a post?
Kev
Originally Posted by appaking
Update:
I went ahead and bought some BSPT 1/4 to 1/4 barbed fittings from McMaster-Carr. At first I thought they didn't fit any tighter than the NPT fittings. They were bottoming out and the biggest end of the taper wasn't getting into the threads. So I ground off about 3/8 " from the threaded end and it fits tight now. Tight enough that I have full confidence it would seal as is. I would probably put sealer or lock-tite on just to make sure it doesn't vibrate loose. I had to buy a pack of 10 of these, so if anyone needs one, drop me an E-mail.
appaking is offline
Libro arquitectura | Loans | Bad Credit Mortgages | Home Loan | Credit Cards UK
1320drag - Drag Racing resource Nissan 240 Forum Audi Forum My Chemical Romance Forum BonneVille Forum Chevrole Forum Camaro Forum Car Audio Forum Car Video Forum Canadian Mutsang Forum Dodge Intrepid Forum Emma Watson Fan Site GM Forum Tuner news GT cars Honda Forum Jeep Forum Mazda Miata Forum RC Forum Mustang Forum Dodge Forum Zero Hurtz
Page generated in 0.44289 seconds with 13 queries
