Old 04-05-2005, 09:17 AM   #1
What is this foam sleeve in the fuel pump kit?
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I got a Walbro 255 fuel pump from TU, and in the plastic bag with all the hoses, wires, fittings, and things, it has 2 foam rubber sleeves, which look like they slide over the fuel pump. One is about 3/16" thick, and the other is about 3/8" thick.
I'm guessing it's safe to put these foam sleeves on the pump and in the tank in the gasoline?
What are they for? Making the pump quieter? If so I'll put the thicker one on.
Tim_K is online now
Old 04-05-2005, 10:02 AM   #2
My Ride: 1994 Caravan turbo!
Images: 4
`I got one of those too. I'm not sure what it was for. I didn't use it
big_P is offline
Old 04-05-2005, 11:47 AM   #3
My Ride: 1988 Daytona ShelbyZ
Engine: 2.2TII soon 2.5TII
What it is, if the kit is similar to the one I got, is a "universal" in tank pump for several applications. When you remove the old pump, you'll see that it is much larger then the 255 pump that you have now and if you install it without the sleeve it will be very loose in the holder. Find the right size foam sleeve for your application and get some petroleum jelly and "lube" up the sleeve, otherwise you'll have one heck of a time trying to get the pump and sleeve ino the holder. Yes I know odd. Once you have the pump fully installed, I wiped off the extra jelly and install it into my car.
I've had mine in my car for about a year and half, and have had no ill effects with the foam sleeve.
I guess the answer to your question is...yes you can install that foam sleeve.
dodge80_89 is offline
Old 04-05-2005, 02:47 PM   #4
My Ride: GLHS, Daytona & SC
Engine: All 2.2 Garretts
Cool, on L bodies is the outside-tank pump still needed?
holley is offline
Old 04-05-2005, 05:16 PM   #5
holley, no the out side pump is just removed. but i have a question for you,
im doing the same install, except someone removed the internal pump on my car and just ran the outside one. could you send a picture of your install once it is all set up and b4 you put it in the tank obvisly. that way i know what goes where since im working from scratch.... thanks
nate moshman10@yahoo.com
or even just say what i have to do...
turbottt1 is offline
Old 04-05-2005, 05:42 PM   #6
My Ride: 88 Shelby Z
Engine: 2.2 T2
I'm using the larger sleeve over the pump body as suggested to mount it in the plastic Bosch-style hanger.
The pump fits this hanger just fine BTW, no need to try and find another style if that's what you have. Just dremel the half-circle in the plastic out wider so that the filter can seat against the pump body all the way.
I also contrived to zip-tie the filter onto the end of the pump so that it cannot fall off. Drilled two holes in the plastic and threaded the tie through them and around the filter where you see the little "ramp" on the filter-to-pump adapter.
D-Cal is offline
Old 04-05-2005, 06:02 PM   #7
ttt1 - I'd be happy to, but it's a looong way off! If I get my scanner out (need to sometime this week) I'll see if there's a good pic of the hanger in the FSM.
My outside pump is making bad noises, but I have lots of other things to do first
holley is offline
Online Loans | Mortgages | Personal Finance | Car Accident Attorney Los Angeles | Gas Suppliers
Page generated in 0.35464 seconds with 13 queries
