Old 04-20-2005, 04:46 PM   #1
Different L.M. than Stage II? T1 > T2
My Ride: 1986 GLH-T
Engine: 2.2L TII convert
I just converted my 86 GLH to Turbo II specs (minus the internals). I installed 1 piece intake, t.b ,etc, Ran all wiring, Running T1 turbo/man. I have a Ford intercooler that came with the car (had a modified log). I have it running right now on a stock GLHS L.M., but it is borrowed. I am searching for a GLHS Stage II L.M., as I posted in "wanted" but I was wondering if there are any other alternatives??
cndnGLH is offline
Old 04-20-2005, 05:12 PM   #2
You can get a re-calibrated L.M., or maybe an 87T2 one would work for you.
Daniel Merrill
89acclaim is offline
Old 04-20-2005, 09:44 PM   #3
My Ride: 1986 GLH-T
Whats the deal on the re cal ones?, I dont know much about them, I obviously want as good or better than the Stage II, Im getting 13psi boost with the GLHS stock one
cndnGLH is offline
Old 04-20-2005, 10:22 PM   #4
My Ride: 1986 GLH-T
Nevermind, I just checked out FWDperformance, DUH.
cndnGLH is offline
Old 04-21-2005, 12:45 AM   #5
There is also http://********************/ they make cals custom to your car.
Daniel Merrill
Old 04-21-2005, 01:05 AM   #6
My Ride: 86 GLHS
Engine: 2.2 Turbo Intercool
Go with turbos unleashed on the cal
BLASINTEBO is offline
Old 04-21-2005, 07:52 AM   #7
My Ride: 1986 GLH-T
Awesome, thanks for the links guys, Now I am confused though, Is turbos unleashed your personal preference or are they proven better? They seem to be a hair more on some stuff, which is fine if it is a superior product (I see thier cheaper for the GLHS stage II). Anyways, which cal do I get now? I'm looking for basically somthing as good or better than the stage II but 15 psi, thats why fwdperformance's stage 3 looked attractive. I'll be running stock map, stock exhaust for now, maybe 3-bar and bigger exhaust next season.
cndnGLH is offline
Old 04-21-2005, 11:56 AM   #8
You can get yours reprogrammed to GLHS stage II for about $50 by Mike Swartz. I don't have his address handy, I'll try to remeber to send it tonight.
Dave Carpenter is offline
Old 04-21-2005, 01:45 PM   #9
My Ride: 86 GLHS
I was in the same boat as you, and That was the cal I bought from FWD-P, but it was too aggressive for my car (86 GLHS) and I burned #1 cylinder... It's pretty potent though, and if you get one I would suggest getting an adj. fuel presure regulator and air fuel gauge.
Old 04-21-2005, 09:56 PM   #10
My Ride: 1986 GLH-T
Yeah, I wondered if it might be too aggresive, after all I'm pretty well stock, Maybe I will stick with a stage II, I would like to make it thru season without blowing up something. Dave, you said he can reprogram mine, but I dont have a TII LM, the GLHS one I'm using is borrowed, I only have an M.P. turbo 1 L.M., that is suspect because I think it got wet.
cndnGLH is offline
Mortgage | Secured Loans | Web Advertising | Credit Cards | Credit Cards
Page generated in 0.34399 seconds with 13 queries
