Old 04-21-2005, 05:09 PM   #1
Intake Air Temp (IAT) Sensor
What is an IAT sensor, and do the 91 daytona's shelbys have one?
Is is needed?
-mark
unclejemima is offline
Old 04-21-2005, 05:28 PM   #2
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
Is is needed?
-mark
No, they don't have the sensor stock but may have the wiring from pin. 21 on the SBEC. It's not needed for a stock cal but can be added if you want when your order a custom cal. The IAT reads the air temp in the intake manifold and adjusts fuel accordingly.
91DSX is offline
Old 04-21-2005, 05:53 PM   #3
The intercooled cars had it, right? But not T1's?
So you're saying the wiring may already be there, is the sensor already there too?
Is it recomended? I plan on 15psi with a cal...
-mark
Old 04-21-2005, 08:36 PM   #4
Engine: SOHC 2.5L
-mark
Yes, all factory intercooled cars came with one. Some T1's had the wiring while others did not, they all don't have the actual sensor itself which looks like a coolant sensor.
If you have the wiring from the pin on the SBEC engine harness(no. 21), already go for it and have the vendor add that into your cal, otherwise there is a lot of trouble to add the sensor as you must melt a new pin into the harness socket.
It's nice to have but with 15psi planned make sure you have a decent intercooler is all.
FYI I have a fairly built setup and am currently not utilizing the IAT at this time.
91DSX is offline
Old 04-21-2005, 09:05 PM   #5
Perfect. That answers my question exactly!
I'm just running a TII i/c front mounted, this should be ok for 15psi? (i have forged venoli's and run 91 octane all the time)
Have any pics/specs of your ride? Thanks, i appreciate your help along the way my fellow 91 Canadian friend!
-mark
Old 04-22-2005, 12:26 AM   #6
Engine: SOHC 2.5L
-mark
No prob at all, I ran into the same issue like you. The TII IC is more than fine for 15psi but am not too keen on the 91 octane but if everything is up to snuff you should be fine overall, and the forged pistons really help just in case.
Hehe, heck I'm running three TII IC's custom fab'd into one core, click the link in my sig for my 91' and it should show some pics of last years unrunning setup. . .new one starts up tomorrow!
91DSX is offline
Earth 4 Energy | Facebook Proxy | Mortgage Calculator | Fast Loans | Car insurance
Page generated in 0.51233 seconds with 13 queries
