Old 04-21-2005, 08:02 PM   #1
20+ injector ?
My Ride: SHOs shelby daytona
I've got a set of 20+ injectors at my house.
Do i need to upgrade my fuel pump to safely run 18 psi with these?
Also i know the answer to this question is probably no, but will the 20+ injectors work with a stock TI?
BittersweetSHO is offline
Old 04-22-2005, 12:17 AM   #2
Dez
if you have an adjustable fuel pressure regulator then yeah they will work with a stock T1...
i am running a set on my 89 lebaron...so far it is running fine...
Dez is offline
Old 04-22-2005, 01:41 AM   #3
If you can run the 20+ injectors with a TI why do you need to change the wiring for the TII injectors?
Mobile Phones | Charity | Credit Counseling | Credit Cards | Debt Consolidation
Page generated in 0.28560 seconds with 13 queries
