Old 04-27-2005, 01:58 PM   #1
Old Fuel Cause Smoking?
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
Ok, new motor/turbo/head, and shes puffing whitish/grey smoke at idle, no PCV valve, just open, but car has almost 2 years old fuel? Will this cause a smoking problem?
91DSX is offline
Old 04-27-2005, 02:30 PM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
yes, so will crud in the exhaust/head/manifold, etc... and new motors will also burn a bit of oil until the rings seat. Go out and give it a good drive if there are no leaks, break it and I bet it stops.
GET NEW GAS before running boost, lol.
Phreakish is offline
Old 04-27-2005, 04:41 PM   #3
Engine: SOHC 2.5L
Gotcha, plugs are fine(rich only from FWD Stg 5 cal) no oil on them, turbo has no shaft play and no oil in the lower IC pipe. Running Wiseco's with tighter ring gap for better sealing under boost. . .I figured a little smoke but this is crazy. . .smells awful too but it hasn't lost coolant or oil. Have you had the same problem before?
91DSX is offline
Old 04-27-2005, 04:48 PM   #4
Engine: 2.2 Turbo
yup, my rampage smoked on 3yr old fuel the first time I fired it... then on my charger - it had new rings (NEW 75 miles total on it) and smoked a bit at idle and decel until the rings seated (about 100 miles more of off/on boost). Then my turbo went, LOL, it smoked at idle, but was obvious it was the turbo.
Old 05-04-2005, 09:07 PM   #5
are you talking white or blue smoke?
-mark
unclejemima is offline
Share Prices | Gas Suppliers | Mobile Phones | Personal Finance | Debt Help
Page generated in 0.33173 seconds with 13 queries
