Old 05-09-2005, 10:33 PM   #31
My Ride: Minivan
Before I went with the bigger injectors and FMU, I was running 10# of boost on the stock injectors. Plugs looked pretty pale so I went with more fuel.
Today I turned the gain down until the AF went lean then turned it back up a hair to get 10 lights...Boost spikes to 18-19psi then settles down to 17...full boost at 4000Rpm. It feels faster...still no wheelspin unless I bring the boost up before I launch.
Speaking of which...how much boost can these 2.5s run on 93 octane?
BoostedToys is offline
Old 05-09-2005, 11:42 PM   #32
every engine is different, and cam and ign. timing plays a large factor. However
I had no problem running 12PSI on my car with no IC and stock injectors with the mitsu still on there 93oct. YMMV.
OmniGuy123 is offline
Old 05-10-2005, 07:06 AM   #33
My Ride: 1999 Jeep Wrangler
Engine: AMC 2.5L
You're probably getting close to the limit at 18-19psi, but there's always alky!
That will gain you another 10+psi!
TRRBOJEEP is offline
Old 05-10-2005, 07:09 AM   #34
Engine: AMC 2.5L
TRRBOJeep...I Alway wanted to turbo a jeep. Except I wanted to do the 4.0 I-6...It looks soooo easy on that motor. Nobody would see it coming
Last Cherokee I had had Factory Posi and the transfer case that lets you drive in full-time 4x4 (AWD)...would have been sick
There is a group of guys out in Yuma, AZ that have turbo'd 4.0L Wranglers. I talk to them every now and then on line. They're pushing 24-25psi + 75hp shot of NOS! They claim they're getting over 600hp to the wheels! (150hp a corner) Now thats a sleeper!
Old 05-10-2005, 09:48 AM   #35
My Ride: Minivan
Hmmm..Alky = +10psi ??? Tell me more.
Old 05-10-2005, 10:21 AM   #36
Engine: AMC 2.5L
Read up on the alky link... 4sfed4 is running 34-35psi on alky!
All you need is a pump, a tank, and an injector nozzle, a presure switch kicks the system on at a preset boost level, and wah-lah, crank up the boost and hold onto the wheel. I should warn you though, it is quite addictive! (sort of like NOS, but much easier, safer, & cheaper)
Free MP3 Download | Charity | Credit Cards | Advertising | Credit Cards
Page generated in 0.33527 seconds with 13 queries
