Old 05-06-2005, 08:23 PM   #1
3-bar map sensor
My Ride: 1989 Dodge Caravan
Engine: 2.5T
i know this topic has been covered many times but i cant seem to find a definate answer for my question. i have a map sensor with gp sorenson PN 77911510. I want to know if this is the correct sensor. i had a 77911502 that i got for a GN. If youre looking at the back of the sensor with the plug at the bottom and the vac source to the right...the first and third connections have a rib at the bottom. i couldnt find anywhere to cross it to GMs PN. any help will be appreciated.
chris
modifyd is offline
Old 05-06-2005, 08:55 PM   #2
729
The 3-bar is the one that was used on the Turbo TA's, GM Part number 12223861 (old part number 16040749). GNs had a 2-bar sensor.
729 is offline
Old 05-06-2005, 09:03 PM   #3
Engine: 2.5T
ok..good. i took the GN one back and got one from the TA. i looked the sensor up in the gp sorenson book for the TA but there were two or three listed for some reason. i got the 77911510 because i recognized the PN from a board discussion. anybody know about the ribs..where theyre located in the connectors? the GN one i had looked exactly the same but with different ribs from what i mentioned above.
modifyd is offline
Old 05-06-2005, 09:47 PM   #4
did the turbo TA's go over 14.7psi boost? i though only the cyclone and typhoon had 3 bar?
-mark
unclejemima is offline
Old 05-07-2005, 11:52 AM   #5
Engine: 2.5T
ttt
modifyd is offline
Old 05-08-2005, 05:49 PM   #6
Engine: 2.5T
anybody?
modifyd is offline
Old 05-10-2005, 01:12 AM   #7
729
16.5 stock PSI. Mine's not stock.
729 is offline
MySpace Layouts | File Hosting | Credit Cards | vBulletin Hosting | Glitter Graphics
Page generated in 0.52177 seconds with 13 queries
