Old 06-25-2005, 10:48 PM   #1
knock sensor and voltmeter
cky
My Ride: 90 daytona shelby
Engine: 2.5 intercooled
can you read the knock sensor when it gets knock with a voltmeter or is the voltage to small or fast ect.
cky is offline
Old 06-26-2005, 01:06 AM   #2
the voltage spikes are too fast to see with a voltmeter, and would be hard to scale anyway. the computer uses a table with knock volts vs rpm to determine what voltage constitutes a knock event at a given rpm, since it varies.
xrattiracer is offline
Old 06-27-2005, 12:36 PM   #3
Before the computer 'sees' the knock signal, the output of the sensor is ran through a band-pass filter, (I believe 2kHz - 5 kHz), to filter out all the garbage. Monitoring knock is do-able, but one would need advanced electronic skills.
GovtContact is offline
Old 06-27-2005, 04:10 PM   #4
WWW.VIATRACK.COM. Boris makes a neat unit that can run an LED when knock is sensed. It'll work with the TD knock sensors...
njansenv is offline
Old 06-27-2005, 04:30 PM   #5
My Ride: 06 GT Cruiser
Engine: 2.4l
I just found that site a fw days ago. And I email Boris about using his setup up with MegaSquirt. I guess is work fine with out any probs. Also there are 2 version that he makes. One with a LED and one that can retard the timing for us if knock is sensed.
TurboMan is offline
Old 06-28-2005, 07:04 AM   #6
It will only retard a Megasquirt setup though, correct?
njansenv is offline
Mortgages | Personal Loans | Broadband | Pay Day Loans | MPAA
Page generated in 0.43535 seconds with 13 queries
