08-13-2005, 07:47 PM
#30
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Originally Posted by DblTrbl
Personally, I've seen more issues with the electrical supply to walbro pumps than tubing diameter. When a high performance pump is as running at 30 psi of boost, that means that the pump is seeing 85psi of fuel pressure and the electrical load (amps) is very, very high. High enough to overload the stock connector and wiring. I'd change the fuel pump wiring and fuel pump connector before I'd change the tubing. I've seen a 20 psi fuel pressure (maximum) increase changing my son's minivan fuel pump wiring.
Carl
I have had this happen on two vehicles already, both equipped with the Walbro 255 ltr/hr high pressure in-tank fuel pumps! On my Shelby Lancer and Shadow ES, it would start to cut out under boost and would run randomly then finally not run at all.
I found the (+) wire on the inside of the tank on the hangar assembly was burnt and corroded badly. The ground wire was fine. I had to fix it by purchasing a new fuel pump/hangar assembly. I reinstalled the Walbro pump in place of the new stock pump, and then upgraded to heavy gauge wire on the hangar, soldering the connections very well, and using a double layer of heat shrink tubing. Another thing that should help is the new fuel pump hangar I bought was for an '89 GTS, which directs fuel straight out the hangar instead of through the curly-Q hose that the '87 style hangar has.
Would this explain my overly rich wideband O2 curve that my Shelby Lancer has? It dynoed 196WHP/242WTQ on a Dynojet with 14 psi boost. It was using stock calibration, 804s, 3" exhaust. The wideband O2 curve dropped off the scale rich as soon as it went into boost all the way to redline. Same thing with my brother's TII '89 GTS which is similarly modded and has the Walbro 255 ltr/hr pump as well. I'm wondering if the stock fuel return line isn't flowing enough and causing rail pressures to rise too high in boost. Would upgrading the return line ease the load on the fuel pump?
