Old 09-19-2006, 03:30 PM   #76
Originally Posted by John B
I have the idea of using two fuel filters in parallel to reduce the filter pressure drop. Good idea or waste of time and money?
Why? we dont' need to run two filters unless your lazy and don't change your filters often enough, lol! I doubt theres much pressure drop thru the filter. Have you done any testing, I would be curious to know?
If your that concerned, buy a System 1 fuel filter. I just got one for my van off Ebay, reusable, cleanable, 30 microns and mega flow,
Old 09-20-2006, 12:32 AM   #77
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
I'll be using Mallory 3160's.
John B is offline
Old 05-04-2007, 07:59 AM   #78
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
interesting question is...Say a stock pump maxes out at 90PSI. If you're restricting the reg to 50psi, the return side should in theory have 40psi?
Where I'm going with this is if you tune your rail PSI down, your return PSI goes up because the Reg bleeds off excess pressure.
DustyR/T is offline
Old 05-04-2007, 06:07 PM   #79
My Ride: '87 Omni
Engine: Dodge 2.2
You're return pressure should be less than 5psi due to there being no restriction in the return line. Of course unless the line itself offers a restriction.
Putter is offline
Old 09-07-2007, 02:35 PM   #80
ednutcracker's Avatar
My Ride: 89' Dodge Daytona ES
Engine: 2.5 l4
using 72psi injectors on a 3bar cal calibated for +40ś could help maintain low fuel presures...afpr old school/???? i say nice
ednutcracker is offline
Problem Mortgage | Fast Loans | Cheap Flights | Credit Cards | Cheap Car Insurance
Page generated in 0.26591 seconds with 12 queries
