Just installed "TorqueFlight's" shift kit - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 35 Old 11-13-2005, 09:54 AM Thread Starter
TD Hardcore User!
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
Thumbs up Just installed "TorqueFlight's" shift kit
We just installed TorqueFlight's shift kit that he built for us. All I gotta say is WOW! This sucker is awesome. If anyone is considering buying one from him, I highly recommend it. At WOT it barks 2nd gear as hard as a friggin' 5spd. This is in our '89 PLymouth Acclaim with just a mitsu turbo, TII i/c, 2.5"exhaust, and MP computer running 12psi. Even at 8psi it barks the tires in 2nd gear.
My dad and I both are very pleased with his kit, he did a helluva job!
Thanks TorqueFlight.
-Bryan
Dave is offline
post #2 of 35 Old 11-13-2005, 01:01 PM
Garrett Booster
How about a little more information on this kit.
XR Tuner is offline
post #3 of 35 Old 11-13-2005, 04:03 PM Thread Starter
TD Hardcore User!
Just go to Member's List on the main page and then go to the T section and find his name. Then PM him.
Dave is offline
post #4 of 35 Old 11-13-2005, 04:07 PM
TD Hardcore User!
My Ride: 1987 Shelby Z
1/4: 10.550
Originally Posted by Dave
...At WOT it barks 2nd gear as hard as a friggin' 5spd...
lol... I'm sure its a pretty good kit, just like the MP shift kit is, but as hard as a 5-speed? not as hard as my 5-speeds hit 2nd!
badassperformance is offline
post #5 of 35 Old 11-13-2005, 04:30 PM
TD Hardcore User!
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
No doubt JT my 5spd will hit as in BURN 2nd to the ground
Garret is offline
post #6 of 35 Old 11-13-2005, 04:46 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
my car's so slow it doesn't even hint at chirping 2nd.
GLHNSLHT2 is offline
post #7 of 35 Old 11-13-2005, 04:50 PM
TD Hardcore User!
Engine: 2.5 16v
It's so true though what do you run? 18s or 19s in the 1/4?
Garret is offline
post #8 of 35 Old 11-13-2005, 05:14 PM
Legendary Driver
GLHNSLHT2's Avatar
hehe, serious though I can't chirp 2nd.
post #9 of 35 Old 11-13-2005, 06:09 PM
TD Hardcore User!
1/4: 10.550
practice makes perfect... I used to chirp 3rd in my '86 Lancer EFI non-tubro 5-speed car whenever I wanted it...
post #10 of 35 Old 11-13-2005, 07:45 PM
Legendary Driver
GLHNSLHT2's Avatar
I think it's the suspension setup and tall 60 series tires that are hindering it.
post #11 of 35 Old 11-13-2005, 10:58 PM
My Ride: '88 Daytona Shelby
Engine: Soon to be 2.4L DOHC
-Bryan
Thanks for the positive feedback. I'm glad you guys like it.
Chad Kilback (reverse pattern manual valve body with trans-brake coming soon)
Calgary, Alberta SDAC
88 Daytona Shelby "Zedd"
12.43 @ 111 quickest time
12.6 @ 113.00 fastest time
87 New Yorker "Norker Zedd" 2.5L TII 14.6 @ 93
Torqueflite is offline
post #12 of 35 Old 11-13-2005, 11:12 PM
It's very similar to the "homemade" shift kit, with the an extra spot or two where I tweaked the valve body further. If I had a working scanner, I could show the extra spots where I tweaked it. Maybe I'll try and explain it in one of the stickys. The tweaking is easy to do, but it may be more difficult to explain where to tweak it without a pic.
I've also figured out how to crank the line pressure (as high as you want to make it, 200 psi if you want to get it that high) on these "homemade" modded valve bodies without it affecting the WOT shift points. I'm currently experimenting with spring tensions trying to find the right one to get the proper shift points. Once I figure it out, I'll let everyone know how to do it. I think extra line pressure will greatly improve on the "homemade" shift kit.
post #13 of 35 Old 11-14-2005, 10:21 AM
Garrett Booster
Thanks for the info. Hope you post the info soon, I am getting ready to rebuild my tranny.
XR Tuner is offline
post #14 of 35 Old 11-14-2005, 11:20 AM
TD Extreme User!
Engine: 2.5L TIII DOHC
That would be great. I finally found a good valve body, did all the mods and found a stronger spring out of a Gil Younger 727 kit. 2nd gear barks and 3rd is rock solid in a stock trans that has no internal mods.
Finding a way to trick the WOT points would be awesome. This governor is stock so it won't shift out of 1st at WOT but thats fine, my strong one should be going back in soon.
post #15 of 35 Old 11-14-2005, 11:49 AM
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
you cant go too high on the line pressure or the drums break (unless you know some special trick that none of us know about)
Brian
Aries_Turbo is offline
Human Verification
