Old 08-13-2006, 07:18 AM   #1
clutch/transmission noise
My Ride: 89 Shelby CSX
Hi,
My 89 CSX has had this "problem" just about since it was new. The only time it went away for awhile was when a new clutch was installed, but then it came back.
the "problem" is that there is a "shirrrring" noise made when the car is in neutral. If I push the clutch pedal in and let it out (still in neutral) this noise goes away.
It sounds as if something is rubbing. (I, honestly, don't know enough about clutches/transmissions to be more specific.)
Is there an adjustment that can make this go away? or, am I such a horrible driver that I somehow caused this to happen.
Any help/info/suggestions/opinions on what to look for would be very helpful to me.
thanks again.
DG
dgrun is offline
Old 08-13-2006, 12:11 PM   #2
Turbo Joe's Avatar
My Ride: 87 csx # 175
Engine: 2.2 T III 16V
Images: 22
that noise sounds like your throwout bearing. when your driving do you keep your foot on the clutch pedal? even a little pressure will prematurly wear the throwout bearing.
Turbo Joe is offline
Old 08-13-2006, 03:23 PM   #3
Joe,
As far as I can tell, I keep my foot off the clutch. perhaps I'm wrong.
either way, thanks for the info and I'll see if that is the problem. At least now I have a direction to go in.
have a great day,
DG
dgrun is offline
Payday Loan | Loans | Mortgage Calculator | Cheap Car Insurance | Electricity
Page generated in 0.50509 seconds with 13 queries
