05-26-2007, 12:27 PM
#61
Attentive Forum Admin
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
The fidanza is nothing like lotashelby's I just sold mine after jackson passed one of his on to me. Played with the shifter in his r/t and it is hard to explain, just know there is a difference and jackson has got the best shifter for our car! the fidanza is disappointing cause only the upper area(where your shifter knob is) seems to be the only difference compared to the stock one.
-Clayton Dennis ~ Forum Admin
HAPPY 4th OF JULY!!! Enjoy the moment, and be safe
05-26-2007, 09:55 PM
#62
My Ride: 1990 Daytona
Engine: 3.0L V6
Well, i got my fidanza STS installed today, i gotta say its pretty short and i'm rather happy about it, i'd say it has about 3.5"-4" through from 1st-2nd gear, when i was watching the video above my post to compare against mine, i gotta say it looks like the same amount of "throw" from 1st-2nd gear as my fidanza unit. Anyhow i'm happy with my new shifter and would recommend it as a cheaper STS to anyone. Now if only i knew what mods (synchro's) would help ease the tension to shift from one gear to another.
05-26-2007, 10:11 PM
#63
Remember I have had both. The throw on the fidanza feels shorter but compare the two it isn't close to 3.5" maybe about 1-1.5. Jacksons' shifter is closer to the 4inch short throw. The fidanza doesn't move much of anything to make a 3+inch difference. i'd be surprise if it made a 2.25inch difference. But for a cheap shifter the fidanza isn't bad. But for a real difference and a real short throw jackson has the best in the market.
08-19-2007, 03:29 AM
#65
My Ride: 89 Shadow
Engine: 2.5 turbo
im interested in one for a late 523. i have a fidonza but not installed. i do notice the pivot point is not really different then stock. i would be interested in getting one for my shadow. i have a core i can send you. just no shift knob. what can the turn around time be?
08-24-2007, 10:16 AM
#66
My Ride: 87 Daytona Shelby Z
i have an 87 shelby z, with the a555 trans. all i would have to do to make a short throw shifter for it is take an inch from the top shaft, weld it to the bottom shaft, and raise the shifter platform up an inch?
09-01-2007, 07:38 PM
#67
My Ride: 1987 Daytona Shelby
Engine: 2.2L Turbo II
I have the same car. What I did to make a short throw, is cut a few inches from the top, and also extend the bottom. IIRC, I removed 3 inches from the top, and extended the bottom by .75". That cut the throw in half! I decided to leave the distance between 1st, 3rd, and 5th the same as it was. I have the ability to retain the reverse lockout if I choose, but with the shift knob I am using, I probably won't.
If you want to see how I did it, I can try and get some pics posted this weekend. I have not installed it in the car yet, since I am waiting on a transmission rebuild kit to come in. It should be a blast to drive though - only 3 inches of travel from 1st to 2nd.
Stephen Anderson
09-01-2007, 08:03 PM
#68
yeah that would be nice. i want to make mine as short throw as possible but i want to keep the reverse lock-out. i have an a555 tranny and dont know if the sts is a definite possibility. please let me know if i can do that
09-01-2007, 08:09 PM
#69
You can definitely keep the reverse lockout. What I did on mine, was cut out a 3 inch section of the upper tube. I tig welded it back together, keeping it hollow in the middle. Now, you will have to fabricate a piece that runs from the reverse locklout ring down to the plastic piece, but 1/4" steel rod is a perfect fit. All you will need is a piece of 1/4" rod with 2 holes drilled in it, and you will retain your reverse lockout.
If you don't want to go through all that trouble, lengthening the bottom piece will also make for shorter throws, but I wanted to get the throw as short as possible, which is why I did top & bottom mods.
Stephen Anderson
01-24-2008, 08:19 PM
#71
Re: Short Throw Shifter?
My Ride: '88 Shelby Z TII
The shifter will physically bolt in, but will not work with the older 4-plane shift trannies(A525,520,555). I personally like the feel of the 4-plane shift better becuase it doesn't use bushings. They use plastic ball-cups and to me they feel a lot more solid. However, if you get some good bushings in the new style cables it does make a WORLD of difference.
03-16-2008, 07:43 PM
#73
My Ride: 89Daytona/99Mustang
Engine: 2.2L Turbo II/3.8 V6
Finally got a 568 in the car. Can you explain how to change out the cable brackets to make the SRT-4 shifter work?
03-16-2008, 08:40 PM
#74
why not PM lotashelbys and have him ship you one of his? I promise with a set of booger bushings you won't believe how much less a throw you have and how firm the shifts are.
04-02-2008, 03:02 AM
#75
so regardless of shorter throw....I think the most important thing is to improve the 2-3 shift.
Bansheenut says his B&M improved the 2-3 shift.
Ive heard that repinning the levers on the trans can help (removing slop) but banshee seems to have a good 2-3 shift without doing that.
So I am interested to try both of bansheenut's shifters because he will have the B&M and Jackson's one of these days.
