8.8 ford lsd- possible to copy for our use? - Page 9 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #121 of 140 Old 01-25-2009, 05:28 PM
My Ride: 90 caravan hearse
Engine: 2.5 turbo
Re: 8.8 ford lsd- possible to copy for our use?
i'm confused also, any step by step instructions with pictures for 7.5 and 8.8 wave spring
TURBOVAN is offline
post #122 of 140 Old 01-26-2009, 12:51 PM Thread Starter
TD Extreme User!
My Ride: 92gtc vert
Engine: 2.5 8v
Originally Posted by Reaper1 View Post
From what I remember some people were speculating that as one wheel turned faster than the other it *could* make the spring possibly cock and jam against the diff pin which could add to the load it exerted.
This is speculation and was never really proven IIRC.
The reason for not just treating the ends of the spring with friction material is heat capacity and also the fact that there is not as much contact area with it(back to the heat thing too). It could also do with possibly screwing up the tempering of the spring when the material is baked on(don't know how hot or how long that takes).
My thought on this may be to weld the spring to a washer then treating the washer ends with friction material, this would eliminate the chance of the spring cocking.
crazymadbastard is offline
post #123 of 140 Old 01-26-2009, 06:44 PM
TD Extreme User!
My Ride: '88 Shelby Z TII
^^possibly, but you'd have to be VERY careful welding it so as not to screw up the heat treatment of the spring!
Reaper1 is offline
post #124 of 140 Old 01-26-2009, 07:55 PM Thread Starter
TD Extreme User!
My Ride: 92gtc vert
Engine: 2.5 8v
I think that is you line stuff up with an actual pin, clamp it all down and just alternate a bunch of tig spotwelds all would be good.
can't believe this thread still grows. :)
post #125 of 140 Old 01-26-2009, 08:12 PM
TD Hardcore User!
My Ride: 97 neon
Engine: 2.4L
No material nedes to be removed to fit the 7.5 ranger spring in a neon diff. Use a rubber mallet to insert, after removing the diff pin of course.
Jack's Dodge is offline
post #126 of 140 Old 02-02-2010, 10:22 PM
My Ride: 1990 Shadow
Engine: 2.5 MPI
so yea any step by steps? good pics? kinda noobish still so i dont even know what trans i have.......
Spr-T-23 is offline
post #127 of 140 Old 02-03-2010, 10:04 AM
TD Hardcore User!
My Ride: 97 neon
Engine: 2.4L
Wow. Been a while. Still have the diff with the F-150 spring on the shelf.
post #128 of 140 Old 02-03-2010, 05:11 PM
Engine: 2.5 MPI
an acurate step by step walk through would be nice, parts lists and prices all in one post, what working in what trannys, how well and how long these springs last?
Spr-T-23 is offline
post #129 of 140 Old 02-03-2010, 05:13 PM
TD Extreme User!
I've got a ford spring, $12 shipped to you.
tryingbe is offline
post #130 of 140 Old 02-03-2010, 05:16 PM
Engine: 2.5 MPI
i can get the parts and im very mechanicly inclinde, certified. i want to know if this can be done in the car, good step by step pics, how that cross shaft retainer goes in. just have alot of questions before i go tearing into my DD you know.
Spr-T-23 is offline
post #131 of 140 Old 02-03-2010, 05:34 PM
TD Extreme User!
Buy a spare transmission and do it on there.
It is very difficult to take the differential out of the transmission while the transmission still in the car.
tryingbe is offline
post #132 of 140 Old 02-10-2010, 10:51 AM
TD Hardcore User!
Well, i wrote out a whole step by step process of getting to the diff in the car (not that i recommend it at all) and somehow it is not here? I posted it like 5 days ago....
Oh well, tough shit because i dont feel like re-writing all that.
Vigo is offline
post #133 of 140 Old 07-28-2010, 12:24 PM
My Ride: 98 Neon SOHC
I'm curious about this as I will be doing it soon to my 1st gen neon trans. Being not easily swayed as I am by the conversation/baby fight that went on on neons.org about the idea, it looks to be as solidly supported as it is here. Like an accepted idea that works.
Is that still the case or have there been tons of epic failures like the "gurus" at the .org would have everyone believe would happen? One guy who admittedly abused the crap out of his trans had a failure and suddenly the thread was locked with the excuse that it was turning into "BS".
Just curious if this is still common practice. I would gladly write up a pic howto when I do mine if it would help.
sketchman is offline
post #134 of 140 Old 07-28-2010, 10:55 PM
TD Extreme User!
Block type "LSD" used in 6000 miles, you'd be the judge.
OBX LSD is a much better option.
tryingbe is offline
post #135 of 140 Old 07-29-2010, 05:54 AM
I did know that that type wears itself to dust. I can think of a few ways to help that, but that's a different story, sort of.
I was more curious if any of these S springs killed transes left and right or if it's a freak thing.
For example, the guy from the .org said that he didn't have the diff pin tabs on, and he didn't install the spring himself either(so who knows how it was done?), and then he beat the crap out of it and it exploded. So, IMO he isn't the poster boy of why not to do it, but it was enough for the ones who mattered to kill the thread.
Human Verification
