02-15-2009, 12:43 PM
#31
Re: flywheel harware issues(may be sticky worthy)
My Ride: '88 Shelby Z TII
With a stock-type or Kevlar clutch, with 250whp or less, I beleive it is a good upgrade and would offer the user a LOT of bennefits with little or no issue. I don't plan on staying in this power range and my clutch is WAY more agressive than stock beign a6-puck cermic. The only place I could see it being a problem is drag racing where it *might* not be able to sink away the heat from slipping the clutch fast and could cause slipping issues. This is exactly the issue I actually have with it drag racing, even with the ceramic disc(which the slipping ruined the clutch, hence replacing it a THIRD time).
For road course and auto-x the aluminum flywheel allows the engine to have much better transeint response(getting from one rpm range to another in a certain amount of time). It also allows for just about effortless rev matching for heel-toe shifts. This is becuase of its low mass and low inertia. These same traits make it hard to drive around town becuase it doesn't store the energy needed to be forgiving starting the car moving from lower rpm, making it easy to stall(I do this quite a bit...it makes me look like a total retard and I hate it). In order to get past this, you have to rev the engine a bit and try to engage the clutch in such a way that when it fully engages the rpms will not drop much past idle. It's not as easy as it sounds and can be hard on the clutch and your leg in traffic if the PP is pretty stiff.
I will conclude this post by saying that in a lighter car these issues may not be as extreme, but my car is a full street trim car, and fairly heavy. Probably on the order of 3100#'s or so.
