Old 05-17-2008, 05:43 PM   #1
523 short throw shifter?
My Ride: 86 daytona CS
I got a 523 out of a 91 spirit can i use a SRT-4 short throw shifter and cabels?
smitty98 is offline
Old 05-18-2008, 12:21 AM   #2
Re: 523 short throw shifter?
My Ride: 1990 Daytona ES
Engine: 3.0L V6
DodgeZ.com
The A568 is similar to the A523 but with harden parts and different FD.
roguetrip is offline
Old 05-22-2008, 12:45 AM   #3
My Ride: 85 Shelby Charger
Engine: 2.2L turbo 1
Originally Posted by roguetrip View Post
DodgeZ.com
I thought the SRT4 had an A543 trans
vader85 is offline
Old 05-24-2008, 11:42 PM   #4
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
you can use the neon short shifter. the housing for the neon and 523 shifters is the same. you can NOT use the neon shift cables. the selector cable is way too long and the cable ends are too large to go thru the shift cable bracket on the trans. someone else posted on here that the cables are the same . i got a complete shifter assembly with cables out of a neon when i was swapping from a
a520 to an a523 in my lebaron. the shifter bolted up perfectly the cables were wrong as described above.
crusty shadow is offline
Old 05-25-2008, 02:19 AM   #5
My Ride: 94shadow, base
I thinks its kinda suprising 15+ yrs later and mopar was still using the same basic shifter setup. with everything being pretty much a bolt on and swap out arrangement. too bad more isnt like that
135SoHc is offline
Mortgages | Remortgages | The eBay Song | Personal Loans | Bad Credit Loans
Page generated in 0.42366 seconds with 13 queries
