Old 07-05-2008, 12:55 AM   #1
2.2 to 2.5 swap
My Ride: Horizon
I'm getting a 2.5 tall block,I have a 85 2.2 with a413 trans. Will the old torque con work or will I have to change it, and If I have to change it will the other torque con work with the 85 trans?
24kilo is offline
Old 07-05-2008, 07:22 AM   #2
Re: 2.2 to 2.5 swap
the entire front pump assembly needs to get changed too. u cant use the newer torque on the older trans and u cant use the older torque on the newer motor
allmotor is offline
Old 07-05-2008, 08:03 AM   #3
Re: 2.2 to 2.5 swap
My Ride: 85 Shelby Charger
Engine: 2.2 T-II
I have good transmissions that will work for you, if you want to go that route.
tmef is offline
Old 07-05-2008, 02:45 PM   #4
Re: 2.2 to 2.5 swap
My Ride: Horizon
Ok, new development, I have the new TC and trans, what do I need to swap to my smaller hubs? I'll have both trannys so can I swap the diffs or do I have to make bastard shafts to go from big spline to small.
24kilo is offline
Old 07-05-2008, 03:22 PM   #5
Re: 2.2 to 2.5 swap
man u just wanna screw around dontcha? how about u take them apart and swap all the parts u need. but u can use a 86 or 87 413 no lockup an u got the smaller shafts.
allmotor is offline
Old 07-05-2008, 04:58 PM   #6
Re: 2.2 to 2.5 swap
My Ride: Horizon
anyone else that can answer the question on the diff
24kilo is offline
Old 07-05-2008, 05:23 PM   #7
Re: 2.2 to 2.5 swap
The answer is in the reply, just pull your small differential and install it into the trans will the big shafts and use the seal housings from the small shafts. And swap ring gears, what's so hard about trying that? But I usually go the other way with the bigger shafts. They've proven a lot stronger in racing applications.
22dodge is offline
Old 07-05-2008, 06:32 PM   #8
Re: 2.2 to 2.5 swap
My Ride: Horizon
thanks, The reason I'm going this way is it's hard to find the hubs and shafts for omni around here plus I have a set of really nice 4 lug pizza's setting in the garage.
24kilo is offline
Old 07-05-2008, 06:39 PM   #9
Re: 2.2 to 2.5 swap
u use the big shafts from a 88-90 omni auto.
allmotor is offline
Old 07-08-2008, 10:04 AM   #10
Re: 2.2 to 2.5 swap
My Ride: Horizon
It was understanding that if I went with those shafts that I had to change hubs also.
24kilo is offline
Old 07-08-2008, 01:42 PM   #11
Re: 2.2 to 2.5 swap
Engine: 2.2 T-II
No, you don't have to change hubs.
tmef is offline
Old 07-09-2008, 11:31 AM   #12
Re: 2.2 to 2.5 swap
My Ride: Horizon
Thanks all
24kilo is offline
Mortgages | Debt | Refinance | Loans | Western Union Money Transfer
Page generated in 0.37181 seconds with 13 queries
