07-30-2008, 08:03 AM
A525 tinkering
My Ride: 1987 Shelby Z
i have an Omni GLH-T rallycross car. I am at the point where i need to do something with the transmission. The gearing isnt favorable.
okay, so i was reading around, and seeing that the old heavy gear set stuff from MP for the A525 is no longer available i was thinking. If the neon transmission internal supposedly fit into my case, could i then use a lot of the neon based MP components? Exactly how much it usable?
I also want limited slip. Welded diff is not ideal for what i do nor is open diff. Could i use the neon diff so something like an OBX is an easy not adapter plate ordeal?
Would the 520 be a better choice for the above?
For further clarification, i want either a taller gear or a better gear set. IE, i need an ACR or R/T transmission gear set and a 3.87 gear for the A525 if i can't use the neon diff. Is the final gear from the A555 swapable? Doesn't look to be as such....
