08-09-2008, 03:27 PM
Re: A413 8 hole into 6 ? help !!!
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
If I'm understanding you correctly, (and this is what I did), you want to use an '86 turbo auto trans with an '85 turbo engine? The '85 crank has 6 coarse thread bolts that hold on the flex-plate, while the '86 & later has 8 fine thread
bolts that hold on the flex-plate. One year flex-plate has 3 torque convertor attaching holes, while the other has 4. Also the pump-drive in the trans was changed for '86. So to use an '85 eng. and flex-plate with an '86 trans you need a special torque convertor that has the bolt pattern for the '85 flex-plate, but the pump drive on the rear for the '86 style pump. I got one from a tranny supply shop in Mich., but they're not that uncommon. In fact, you can get it with several choices of stall speed's. No, Bastard isn't the name brand, but that's what they called it. I just stole the word from them.
They were near Hazel Park Race track. That's where they race horses. Someone on here who's in that area should be able to help further.
Any help guys?  Use the '86 starter also, yes.
Reason: Starter info
