04-27-2003, 11:43 AM
My Ride: 91 Eclipse GSX
Engine: 2.0
you will need the flexplate and bolts, tranny, wiring for the neutral safety switch,brake pedal and pin,shifter and cables(1 shift selector cable, 1 kickdown cable) possibly the bracket at the throtle body that the kickdown cable attaches to, your motor should be a 6 bolt so you will need a 86 or older tranny out of any FWD Dodge unless its a 87 Omni or Charger than it will work
