04-28-2003, 06:47 PM
Re: How to check line pressure
Originally posted by altered7151
I just got my mvb and remember hearing stories that the line pressure has been set too low on some off the units and needs to be turned up. Is this still true and how do I check the pressure?
The line pressure has been set too low on "some" units but I feel like "all" is more appropriate. I installed mine straight out of the box and it's shift quality was exactly like stock. You really have two options:
1. Send MVB to Gary Donovan "Relentless Performance" for modification (get in touch w/him and he will explain why) in short the MVB's were designed in the carbed 2.2 era.....things need to be "tweaked" to bring them up to turbo spec. I have done this to mine......best mod per dollar spent besides the G-Valve!
2. Adjust the line pressure yourself before install....which is done by turning the line pressure adjustment counter clockwise. You will still not be able to obtain the desired line pressure when fully adjusted out.....I tried!......it was a improvement mind you, but still not what I wanted or expected.
There is also a mod to make your tranny externally adjustable which I have done......it's nice to have but thus far I have found it not neccessary with the Relentless modded MVB as mine seems perfect.
Hope this helps
