Hi Jori, hi all
After removing the TCM and all the plugs, I first had to removed the isolation and i found following mess:
All the plugs except the connection to the TCM look this way:
These are the available plugs:
I removed all wired, leading to the TCM, to the relais and could separate the 1big black plug and two 3pin plugs:
Obviously the big, black connector is used and not the white one
, i suspected, first...There are 3 wires leaving this black plug:
a thick blue one -- leads to 1 side of the 3pin black connector
a thin brown/red one -- leads to the middle of the 3pin grey plug
a thin yellow/brown one -- leads to the the middle of the 3pin black plug
The wires leaving the big rectantular black plug (the ones to the left are chopped off, already):
The 3 pin black plug (only the middle + 1 side wire lead to the grey rectangular plug, the blue and the yellow/browne one (purple one is chopped off)):
The 3 pin grey plug (only the middle brown/red wire is connected to the rectangular black plug, all others are chopped away):
The two 3pin plugs (grey + black):
So, if i understood and checked your comments, i should now do as follows:
- reconnect the black rectangular plug
- as i beleave it is the black plug, you were writing about, i take the blue wire
and the yellow/brown wire
- as the grey one -->
please confirm this <-- is not used, i will chop
off the no more used brown/red wire, too
BUT: Where shall i connect the 2 wires, the yellow/brown and the blue one?
There is a 2 pin socket on the A543 (manual transmission) as seen on this picture:
Where shall i connect which wire, does it matter?
Can U please help again?
Thank U a lot
Bruni
