Old 04-30-2003, 03:26 PM   #1
is my tranny dead?
My Ride: 91 RT/87 Shelby
Engine: 2.2 T3 and T2
okay. I think I found the source of my knocking sound. The input shaft on my tranny wiggles quite a bit. I can actually see bits of metal inside the seal there. There's also tranny fluid IN the torque converter. I'd think that would mean that the bearing is going out??
I also pulled the pan off and there was a good ammount of metal IN the pan and on the outside of the valve body.
Can someone confirm that this would cause my knocking sound that I was hearing, and the loss of power. When I pulled the car into the garage, I noticed that no matter how much gas I gave it, the car didn't want to move. My Dakota did the same thing when the tranny died
shelbydz is offline
Old 04-30-2003, 08:49 PM   #2
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
The tranny sounds dead. No big deal. Throw it away and find another one at the wreckers.
LancerShelby is offline
Old 05-02-2003, 12:05 AM   #3
that's what I needed
that's what I wanted to know. I can swap a tranny out no problem, but I wanna make sure that's the problem before I go and spend $75 at the yard.
thanks
shelbydz is offline
Old 05-02-2003, 12:28 AM   #4
There should be tranny fluid in the torque converter.
ShelbyMotorspts is offline
Old 05-02-2003, 09:47 PM   #5
Re: that's what I needed
Engine: 4cyl. 2.5L
thanks
You found the problem, lots of metal and a loose shaft. There should only be a fuzz of metal on the magnet, no more.
Credit Counseling | Loans | Credit Counseling | Mobile Phone | Mobile Phones
Page generated in 0.33405 seconds with 13 queries
