Old 05-14-2003, 12:57 PM   #1
A520...2nd gear popping out occasionally...
Just want to get some opinions on this. Probably the 2nd gear syncro is bad/going bad? It never grinds or anything. I just noticed that when I thought it was in gear(2nd) the past 2 mornings that it had either popped out or didn't go into gear. Thanks.
Christian J. Grest
BUBBA is offline
Old 05-14-2003, 05:30 PM   #2
My Ride: 82 Rampage
Engine: 2.4 16V turbo. NGC M
2 possibilities I can think of either the shift fork pad is worn out (probable) or the snap ring has broke and the 2nd gear has been pushed away from the syncro..but this would also give you problems in third gear too.
Dean Stillie is offline
Old 05-14-2003, 07:28 PM   #3
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
I had that problem with my stock 555, the 2-3 syncro was crap.
LancerShelby is offline
Old 05-15-2003, 06:35 AM   #4
Yea, I was planning on upgrading the tranny soon anyways. Hopefully it'll last a while longer till I have the cash to get another one. Definitely gonna cut down on my track time. Thanks guys.
Christian J. Grest
BUBBA is offline
Old 05-15-2003, 11:14 AM   #5
My Ride: '89 CSX T3/T4
Engine: 153ci
i had that same problem when i finished my 520 swap. clutch in, put it in 2nd, clutch came out and so did the shifter
so i just adjusted my cables according to the 2.2/2.5 FWD book and it works perfect.
that might be your problem
TurboXT is offline
Old 05-15-2003, 03:04 PM   #6
Yea, a buddy of mine asked if I checked any of the cables/linkages, which I haven't. I've gotta get a FSM for this thing cause the Haynes isn't cutting it. Do you happen to have a how-to on how that's done or can you scan/send me a copy out of the service manual you used? Thanks.
Christian J. Grest
BUBBA is offline
Old 05-15-2003, 08:53 PM   #7
My Ride: 91 Eclipse GSX
Engine: 2.0
if it pops out when u get on it than its synchro's you could have stretched the cable which might need adjusting, remove the shifter console and you'll notice the adjustments, adjust while fully engaged in 2nd making sure you are getting full throw if that don't help than you'll have to dig deeper into tranny
flybyuin2.2 is offline
Old 05-16-2003, 06:22 AM   #8
It definitely doesn't pop out when I get on it in 2nd gear, so I guess it is an adjustment problem. I'll take a look at those linkages this weekend if I get a chance. Thanks for all y'alls help.
Christian J. Grest
BUBBA is offline
Old 05-16-2003, 02:30 PM   #9
Engine: 153ci
i cant scan it and i cant even take a pic of it for you because my camera is in Utah. sorry
TurboXT is offline
Old 05-17-2003, 07:08 PM   #10
Ah, no problem. I haven't had any time to mess with it this weekend cause the rain and work. I did get on it a few times in 2nd at 20psi and it didn't pop out or anything, so that almost definitely means it's an adjustment issue.
Christian J. Grest
BUBBA is offline
Old 05-17-2003, 08:04 PM   #11
Engine: 153ci
yup. i remember when i used to get on it and it wouldnt pop out. only when driving normal.
TurboXT is offline
0 Credit Cards | Credit Card | Personal Loan | Bad Credit Mortgages | Xbox Mod Chips
Page generated in 0.36890 seconds with 13 queries
