Old 05-26-2003, 03:41 PM   #1
clunking?
ummmm, what's it mean when you shift to third gear and it sounds like a large aluminum baseball card in some large steel spokes? and then gets louder if you give it gas? jeez, i can't believe it's possible that i fegged up my tranny already. *sigh* well, it's a 520. rebuild it? get a 555? what's a rebuild cost in florida? should i just get another from the junkyard?
thanks
tony
macncheese is offline
Old 05-26-2003, 06:10 PM   #2
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Does it do it in all gears? Louder and faster as the car picks up load/speed? If you answered 'yes', then it sounds to me like the output shaft bearing failed. I've had two A520s fail like this on me in the past year.
The Lancer's was replaced with an A555; the Shadow's was replaced with an A568. So far so good.
iTurbo is offline
Old 05-27-2003, 11:13 PM   #3
well, i hear light clunking, like something bouncing a little inside, but when i shift it to third, allmight hamsters with jackhammers go crazy!! i'm off to the yard tommorrow to find a suitable replacement.
tony
Old 05-28-2003, 01:05 AM   #4
SDaytona89
FWIW
The Chrysler 465/525/520/555 manual transaxle has a problem with bearing plate deflection at high hp levels . The factory plate is mild steel which deforms causing the input shaft bearing to lose it's preload and spread the gearset apart causing destruction of third gear. 1990-1993 523 & 568 transaxles are not affected by this problem.
It happened to me LOL!
This is from Gary's site....Source
Old 05-28-2003, 08:45 PM   #5
so i should've gotten that 523 today at the yard instead of the 520? ****
tony
MPAA | Song Lyrics | Honda CBR600RR | Investing | Online Loans
Page generated in 0.47572 seconds with 13 queries
