05-27-2003, 05:55 PM
My Ride: 1986 GLHS #126
Engine: stock
you need to do 2 simple, cheap things:
1. install a new seal
2. polish and inspect the axle seal area (the outside diameter of the axle that meets the inside diamter of the seal). use a fine wire brush or fine sandpaper and buff/polish that axle o.d.
if the unit has a severe deep gouge, or dent, polishing wont do much good.....then you will need to replace that unit.
