Old 05-27-2003, 07:31 AM   #1
5w-30 synthetic motor oil?
Are you supposed to use fully synthetic motor oil in the 555's?
shelbyglhs222 is offline
Old 05-27-2003, 09:06 AM   #2
My Ride: 91 Stirit R/T
Engine: TIII 2.2
Yes, it is fine to run the synthetic in the 555's. I use mobil one 5w30 in winter and go to 10w30 for summer.
Greg
unluckyty is offline
Old 05-27-2003, 10:25 AM   #3
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I wouldn't do it, but I don't think it will hurt anything if you do. I have Mobil1 synthetic 5-30 in my A555 and it is a bitch to shift when pushing the car hard. You really have to concentrate on shifting/clutching or it just won't let you into gear.
iTurbo is offline
Old 05-27-2003, 11:39 AM   #4
It can be too slippery for the snycros and make it harder to shift. Thats what I hear anyway. You might want to try some GM syncromesh fluid. Its what I run in the mustang and it did help it shift a little smoother.
DarkWolf is offline
Old 05-27-2003, 12:26 PM   #5
My Ride: 1987 Shelby GLHS 189
I run 5/30 synthetic in my 555 and all the 520's I've had. Never an issue with shifting.
BUT, Cliff is the expert and he says to run regular 5/30 due to the "slippery" issue and shifting.
glhsken is offline
Old 05-27-2003, 01:37 PM   #6
I want to try the GM Synchromesh, but that stuff is expen$ive. My brother uses it in his Olds Cutlass (Getrag 282 5spd) and there is a guy here in town that uses it in his Ford Taurus SHO. They both like it a lot.
The only time I have problems shifting the A555 in my Lancer is the 1-2 shift. If I wait too long and don't short shift into 2nd, it's really hard to go into gear. It seems like I really have to plant my foot all the way down on the clutch. It's like it engages to far down.....Maybe synth is not to blame?? Wrong clutch cable or worn synchros?
iTurbo is offline
Old 05-27-2003, 01:45 PM   #7
No...the shifting is fine....I was just a little concerned about my loud throwout bearing noise when the clutch is up, and thought I may have put in the wrong oil.
Old 05-27-2003, 05:58 PM   #8
My Ride: 1986 GLHS #126
Engine: stock
what ken said above is true...cliff highly recommends and uses only regular oil, not synthetic, in all his high perf tranys.
he just built me a custom hybrid a-525/555 and used regular high grade 5w-30 oil, not synthetic.
Marcus86GLHS is offline
Old 05-27-2003, 06:21 PM   #9
My Ride: mostly mopar
Throw out bearing is not affected by the oil. It is not lubricated by it. Has its own lube.
BLUEBALL is offline
Old 05-27-2003, 08:21 PM   #10
Royal Purple and Amsoil both make synthetic oils specifically for manual transmissions. Has anybody tried them?
Shelby VNT is offline
Old 05-28-2003, 02:20 AM   #11
Well you can get the Pennzoil version for around $6 a quart which isn't too bad. I didn't find any locally till right after I bought the stuff from GM for $10 a quart thoough . Oh well it not like it need changed that often.
DarkWolf is offline
Old 05-28-2003, 03:06 PM   #12
MrCSX55's Avatar
My Ride: 87 CSX #55
Engine: 89-2.2 c-block
I changed mine from syn. to reg 5w/30 when I change the end plate. It seems to shift better.
Later
MrCSX55 is offline
Loan | MPAA | Military Videos | Loans | Mortgage
Page generated in 0.51990 seconds with 13 queries
