05-31-2003, 10:37 PM
Well, with a little more research - the Spirit R/T clutch is outta the question. From Gary D's website...
1. 82-85 6 bolt crank, small 215 mm pressure plate pattern.
2. 84-84 6 bolt crank, large 230 mm pressure plate pattern.
3. 86-94 8 bolt crank, small 215 mm pressure plate pattern.
4. 86-93 8 bolt crank, large 230 mm pressure plate pattern.
5. 91-93 16 valve 8-bolt/230 mm p.p. with crank trigger slots.
The 230mm are for Turbo's, 215 is a Carb/TBI. I'm guessing I have the #2 flywheel, 6 bolt - although I'm not positive on how to measure the pattern, my dowel pins are 230mm spaced or so. Is that correct? I'm pretty sure mine should be off a Turbo anyhow.
I'm getting myself all confused now... even though I measured the bolt holes differently between the 6-bolt and 8-bolt flywheel I have laying around - would the pressure plate still fit from a 86-93 because it has the same P/P pattern?
