Old 05-31-2003, 06:37 PM   #1
Question Auto or Manual in my van: Need advice!
Ok guys,
Here is the story:
I am building my 89 turbo Caravan with a goal of 400-450 hp.
Before everyone says "Yeah right", keep in mind we are building this as a promotional vehicle for my company and sparing little to no expense (think DFI system, relentless stage III heads, etc).
Now, the dillemma:
What tranny is the most bulletproof setup we can obtain?
Currently it has the a413. I have two issues with it:
1.) No Quaife lsd. I believe fwd motion told us they had a kit to "convert" the neon Quaife lsd for use with the a413. However, we were told it was $1500 and may void the Quaife warranty. Also, does anyone know if this exists yet??
2.) RMVB: Usually people run an automatic for drag racing if they want high levels of consistency. However, with the manual valve body isn't that negated?
My current thinking:
Install a 568 manual tranny, revlock clutches, quaife diff. Will this hold up? (Keep in mind we would have Cliff Ramsdale do the rebuld/etc on this).
Thanks in advance guys.
freudie1 is offline
Old 06-01-2003, 07:16 AM   #2
From what I have seen, yes. I am doing the exact same thing. You will be into it for half again as much if you fortify the auto for drag strip use. The diff pin WILL self destruct.
I am going 568 (swap is going on right now) on my van with a Stage II clutch. Supposedly its good for around 400 reliable horsepower with no diff issues.
mtrainVR6 is offline
CreditCards | McDonalds | Mortgage Calculator | Bleach Episode | Mortgage
Page generated in 0.39618 seconds with 13 queries
