89 Lebaron Rack and Pinion replacement - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 8 Old 10-19-2011, 02:42 PM Thread Starter
My Ride: Dodges
Ok, I've been reading on the forum and I've got a Chiltons manual(which is just about worthless. It's got to cover 15 years of FWD Chryslers) about changing my Rack and Pinion. the seal on the drivers side is gone and I don't think it's worth it to just do the seal. Everything I see says to drop the K-frame. It's a J body car. I've changed FWD chryslers before, and did not drop the K-frame. On top of that , I looks like I can pull it straight out once everything's undone. I'm a little apprehensive about dropping the K-frame. Has anyone done this before or has everyone dropped the K-frame?
chrisd is offline
post #2 of 8 Old 10-19-2011, 02:45 PM
Daytona Junkie
Re: 89 Lebaron Rack and Pinion replacement
i just did my shelby z in june, i didnt drop the K-frame
post #3 of 8 Old 10-22-2011, 03:07 PM
My Ride: Chevys and Mopars
i was a Dealer tech from 1983 - 2000
Drop the k fram down. Leave the lower ball joints in. 4 bolts alot more room.
Some times we popped the lb's out and left the rack on the k-frame swapped it out on the jack.
Capt. Chrysler
Capt Chrysler is offline
post #4 of 8 Old 11-29-2011, 10:42 PM
My Ride: 89 lebaron
If this helps at all, I was able to pull mine out through my driver side wheel well. Wasn't that bad, but I work at a shop with a lift and it might be difficult to some degree doing it on the ground.
tmccammond is offline
post #5 of 8 Old 01-03-2012, 05:27 PM Thread Starter
My Ride: Dodges
Well, I finally got the holidays and a few other things behind me and changed the rack. I didn't drop the K member and had no issues. But, I found I've also got a bad power steering pump. Oh well, what can you expect for $500.
chrisd is offline
post #6 of 8 Old 01-03-2012, 05:33 PM
Just A Guy
NAJ's Avatar
If a pump is run low on fluid and/or has to work too hard it will fail so your rack issue killed your pump.
post #7 of 8 Old 01-03-2012, 06:42 PM Thread Starter
My Ride: Dodges
Yeah. When I change the pump out, I'll do it right and change the hoses too.
chrisd is offline
post #8 of 8 Old 01-03-2012, 06:44 PM
Just A Guy
NAJ's Avatar
Just be sure you bleed it properly.
Human Verification
