Old 04-01-2004, 05:14 PM   #1
A555- Removing Anti-Spin Pin for Thrust Washer
Are these anti-spin pins normally pressed into the intermediate shaft? I can't get this one out and the manual says nothing about it. Can I just grind the pin off flush with the shaft and put a new pin in the hole that's on the other side of the shaft (180* from the original pin)? I can't get 2nd gear off until this pin is gone.
Thanks for any input,
laserxe84 is offline
Old 04-01-2004, 05:38 PM   #2
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
No, they should come out. Use a strong magnet.
minimopar is offline
Old 04-01-2004, 07:30 PM   #3
I don't think a magnet will pull it out. I can get a good grip on it with some needle nose pliers, but the pin does not move at all. I can't even get it to spin in it's bore it's so tight. The only other time I rebuilt an A555 was because of a cracked case. I found the thrust washers and snap ring in pieces as well as the anti-spin pin in the bottom of the case... So I guess that pin was loose...
Old 04-01-2004, 08:27 PM   #4
Engine: 1987 2.2L
Hmmm...well on the trannies I have worked on, it always comes out. The only thing holding it is the suction that results from the oil. Maybe try clamping on a pair of vise grips and walking it out.
Old 04-01-2004, 09:54 PM   #5
Russ is correct, they are a loose fit pin but I have had a few occasions over the years where I couldn't get the pin out, no way no how.
I had to find a replacement shaft for one because it was for the thrust washer between 2nd and 3rd and with the pin in there you can't remove 1st, 2nd or the syncro assembly.
Cliff Ramsdell
VP New England SDAC www.sdacne.com
'86 K-Car Wagon 2.5 TIII, 568
Mopartek@aol.com
http://www.members.aol.com/mopartek/home.html
Coming soon: http://www.mopartek.com
Cliff Ramsdell is offline
Old 04-01-2004, 10:23 PM   #6
Couldn't I just put a new pin in the blind hole on the other side of the shaft and grind the old pin down with a Dremel? -being very careful not to grind 2nd gear or the shaft, of course
Thanks for the input,
Old 04-02-2004, 08:07 AM   #7
You sure can.
Cliff Ramsdell
US Distributor for T-Trac Posi units.
Mopartek@aol.com
Credit Cards | Credit Check | eBay | Mortgage Calculator | Homes for Sale
Page generated in 0.35154 seconds with 13 queries
