Old 08-07-2004, 01:11 AM   #1
Chatter at the start of 1st and 2nd gear
I have been getting some chatter at the start of 1st and 2nd gear...
I am not sure if thats the way it should be...
3rd gear feels a little sticky shifting to it...
Also I get a low noise when in neutral...goes away when I press the clutch.
Vaughn
vsman77 is offline
Old 08-07-2004, 10:02 AM   #2
What kind of clutch? Car? etc?
Some more aggressive clutch disks will do that, usually worse when new and not broken in.
If it's a stock clutch, you're probably down to the rivets and need to replace the clutch and pressure plate and likely have torn up the flywheel and will need to surface it or maybe even replace it.
spoolboy is offline
Old 08-09-2004, 12:04 AM   #3
Or your motor mounts are shot and lettting the powertrain move around. Check those first, if ok, then Spoolboy is bang on.
Old 08-09-2004, 01:25 AM   #4
Well, Its an A-555 in a 89 plymouth voyager...
I just changed the clutch, pressure plate and throwout bearing...
The clutch was from Autozone...
I was told it may be the input shaft.
Vaughn
vsman77 is offline
Old 08-09-2004, 12:02 PM   #5
Did you machine the flywheel? Did you clean off the disc, pressure plate and flywheel with brake cleans to degrease them. The PP's usually are covered with an anti rust coating-if you didn't remove that, then you found your chatter!!!!!!! Doh!
Old 08-09-2004, 01:23 PM   #6
My Ride: 1988 Dodge Daytona
Engine: 1988 2.2L Turbo II
Did you remember to grease the input shaft?
SilverShelbyZ is offline
Old 08-09-2004, 04:21 PM   #7
My Ride: td
I am getting the same sound as you mentioned(I think). I also have an a-555, new cluch, and in a minivan. so...btt, i hope its nothing to wory about.
Geoff is offline
Old 08-10-2004, 12:44 AM   #8
Yes, I was very careful when replacing everything. I washed my
hands constantly and cleaned everything with brake cleaner.
It felt like I was working in a hospital...
Is there a pilot bushing with this trans? It seems like there should
be something to hold the input shaft steady.
Vaughn
vsman77 is offline
Old 08-10-2004, 11:49 AM   #9
How are your motor mounts?
Old 08-10-2004, 01:00 PM   #10
My Ride: 1984 Daytona
Engine: 2.2L Turbo 1
no pilot bushings in our fwd cars. The input shft is held by two bearings inside the trans. One at the far end by 5th gear and one just behind the front seal.
SwiftTech is offline
Old 08-10-2004, 01:56 PM   #11
Thanks, my bearings could be bad...
Is there a rebuild kit that includes those.
Vaughn
vsman77 is offline
Old 08-16-2004, 02:55 AM   #12
Whats a good way to test the mounts without removing them??
Vaughn
vsman77 is offline
Old 08-16-2004, 11:38 AM   #13
Vaughn
Take a good look at them first, then have someone put the e-brake on and the reg brake and give it gas, let the clutch out and make the engine move, it shouldn't move that much, look at the mounts as he/she is rocking the engine a bit, you can see a broken or worn motor mount pretty easily but even if there sort of good, change them with some MP, right side and front, or quickor or other brands, there stronger and can take the abuse better.
Old 08-17-2004, 03:40 AM   #14
Now what about the left mount?
vsman77 is offline
Old 08-17-2004, 01:38 PM   #15
Sorry, not familiar with 5 spd left mounts but same applies, shouldn't move too much!
iPhone Reviews | Ringtones | Bad Credit Loan | Credit Card Debt Consolidation | Advertising
Page generated in 0.41950 seconds with 13 queries
