Old 09-06-2004, 12:12 AM   #1
best gear oil for A543?
My Ride: 1990 Daytona ES
Engine: 3.0L V6
Hi all, i was reading on allpar that the best thing for the A568 is 5w30 oil and says basically the same for other 5 speeds, I just did a 5-speed swap on my daytona with a tranny out of a donor car, i lucked out and all the gears work great. My question is 5w30 the best things for these trannies? I was gonna get some redline 75w90 or whatever but held off because I wanted to look up what was appropriate or best for these.
Thanks in advance!
92 Stealth ES DOHC ATX
92 Lebaron Convertible V6 ATX (for sale)
90 Daytona ES V6 ATX-2-MTX swap
roguetrip is offline
Old 09-06-2004, 01:07 AM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
75w-90 would be very bad in these trannies, you'd probably have a really hard time shifting. I myself use 0w-20 in my tranny, Mobil 1 synthetic. I've heard a big debate over synthetic vs dyno oil in these trannies. synthetic is obviously better for bearing life. dyno is supposed to be better for the synchro's. Blend the two and have the best of both worlds..
Una is offline
Old 09-06-2004, 02:34 AM   #3
The t5 in my mustang uses 5w30 but I am running GM syncromesh after seeing a lot of the guys on the mustang forums use it. Seems to work pretty well to me. Its not cheap but if you can find the Penzoil version you can save a couple bucks.
DarkWolf is offline
Old 09-07-2004, 05:13 PM   #4
i run gn syncro mesh too, its great oil, do some reearch on the dsm boards they sweat but it, napa carries the cheaper syncromesh
mopar3.0 is offline
Old 09-08-2004, 12:59 PM   #5
I like to run one qt of 5w30 and one qt of redline MTL
later
daytonairoc is offline
Old 09-08-2004, 01:41 PM   #6
My Ride: 87 Shelby Charger
Engine: 2.2l 135CI
Redline MTL
mw6886 is offline
Old 09-08-2004, 01:56 PM   #7
My Ride: Spirit R/T
Engine: TIII
i use only GM Syncromesh in my Getrag 282 5-speed, and Valvoline conventional 5w30 in my A555. i've thought about trying Syncromesh in my A555, but so far i don't really have any reason to; the 5w30 seems to be great. besides, Syncromesh is like $10/quart!
Joshua Mitchell
'89 Lebaron GTS -T2/A555
'91 Cutlass Supreme sedan - 3.1 MPFI/Getrag 282 5-speed
malibuolds is offline
Car Loan | Mortgage Calculator | Investing | Loans | Bad Credit Mortgages
Page generated in 0.38290 seconds with 13 queries
